Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2004 Location: Pinas Age: 34
Member: 91411 Status: Offline Sonork: 100.1584444 Thanks: 1,355
| LG KG110 repaired with flashing process this unit came to me for repair with program problem.when turned on the unit just hangs in the main menu.i hope this serves as reference for all of us....all i did was flash the unit with alchemy data and calibration files from the support site and load it then flash the unit... ![]() ![]() Logs For Flashing: COM4 [VCP0] selected Device: LG KG110 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" enabled "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 352691014915805 current otp imei: 352691014915805 file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_35269101491580 5_LG KG110_beforeflashingbackup20080124-154422.B1E.bin . . . . . . . . version: ***-XXV10gARBKG110P40 Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) calibration area skipped flash: 01227E22212200:FEEA0000000000 Write: Alchemy data flash: 01227E22212200:00000100000000 write: 2nd chip area Write Done Finished, time used: 370 sec Remove/Install battery now ! after flashing the unit is now well and full functional. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| lg kg110 repair service not available | sanjubhai | ET-BoX | 3 | 04-11-2010 11:30 |
| LG kg110 repair imei problem | zeerik | Infinity-Box | 6 | 12-07-2008 10:32 |
| LG KG110 dead after flash | JC_BY | Infinity-Box | 2 | 03-04-2008 17:22 |
| LG-KG110 Restarts with SIM card | GsmXplorer | Infinity-Box | 1 | 09-26-2007 21:18 |
| LG 510w problem with flashing | BufferMess | LG | 2 | 11-03-2003 09:41 |
