09-13-2008, 15:50 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Ghana Age: 40
Member: 563167 Status: Offline Thanks Meter: 39 | Lg kg130 dead still dead Device: LG KG130 Checking data, wait... advanced flash detection active Action: flash write Skip: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" enabled "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done Check flash... warning: wrong data size at 0x01000400, retry... warning: wrong data size at 0x01000400, retry... warning: wrong data size at 0x01000400, retry... read error recovered warning: wrong data size at 0x01002000, retry... warning: wrong data size at 0x01002000, retry... warning: wrong data size at 0x01002000, retry... warning: wrong data size at 0x01002000, retry... warning: wrong data size at 0x01002000, retry... warning: wrong data size at 0x01002000, retry... read error recovered warning: wrong data size at 0x01003400, retry... read error recovered warning: wrong data size at 0x01003800, retry... warning: wrong data size at 0x01003800, retry... warning: wrong data size at 0x01003800, retry... warning: wrong data size at 0x01003800, retry... read error recovered warning: wrong data size at 0x01003C00, retry... read error recovered warning: wrong data size at 0x0100A000, retry... warning: wrong data size at 0x0100A000, retry... read error recovered warning: wrong data size at 0x0100A800, retry... read error recovered warning: wrong data size at 0x0100AC00, retry... read error recovered warning: wrong data size at 0x0100B400, retry... read error recovered warning: wrong data size at 0x0100D000, retry... read error recovered warning: wrong data size at 0x0100D800, retry... warning: wrong data size at 0x0100D800, retry... read error recovered current eeprom imei: 355311010917484 current otp imei: 355311010917484 file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_35531101091748 4_LG KG130_20080913-141211.B1E.bin ....... version: 262-01V10a49KG130P40FL Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Alchemy data calibration area skipped flash: 01227E22212200:FEEA0000000000 flash: 01227E22212200:00000100000000 write: 2nd chip area Write Done Finished, time used: 1789 sec Remove/Install battery now ! master pls i need ur advice bcos phone has been flash 4 so many files but still dead. i mean totaly dead............? |
11-04-2008, 22:53 | #4 (permalink) |
Junior Member Join Date: Jan 2006
Member: 224789 Status: Offline Thanks Meter: 19 | KG130 fullflash but stil dead Hello, Did you tried to use full_flash files from support area ? \flashfiles\LG\KG130\full_flash kg130 fulflash & wreite backup eeprom but stil dead! what can i do Sir ? anay help? |
11-04-2008, 23:45 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hello, What is your phone history ? Did you checked phone hardware ? If phone still dead after full flash you have a big reason to check phone hardware. |
LG kg130 dead after flash with HWK | mihaser | LG | 6 | 04-20-2012 04:28 |
6280 dead, still dead | Dziuba | MT-BOX | 4 | 07-08-2008 20:32 |
LG 8110, full flash but still dead | Arif Jamil | LG | 3 | 11-23-2007 09:12 |
V200 dead by LG charger -capaciotors reset it but still dead | crossings | Samsung Hardware Repair | 0 | 12-29-2005 12:06 |
T610 alive.....now dead......still dead.. | gsm2 | DIV | 3 | 01-23-2005 20:11 |
