>>> LG KG130 unlocked success <<< LG KG130 (Virgin Mobile) unlocked successfully with Infinity Box. Thanks to the great team.... COM5 [VCP0] selected Device: LG-KG130 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 355311017397466 current otp imei: 355311017397466 file saved: C:\Program Files\InfinityBox\LGA\eeprom_355311017397466_LG-KG130_20080823-172719.B1E.bin ....... version: 234-30V10a44KG130P40FL Check flash Done Check space... current eeprom imei: 355311017397466 ................................ finalization done Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done Finished, time used: 47 sec Remove/Install battery now ! |
nice move bro.......good work... congrats! |
nice reference brother continue sharing |
@zeel_zeel Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
thanx bro thanx for sharing your experience.;) |
