08-08-2009, 16:52 | #2 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Islamabad--Pakistan
Member: 194128 Status: Offline Thanks Meter: 303 | @maanarman Did you tried to follow the instructions written in the file named "LG-KG300_KG200_KG195_repair_freez_restart" on your hard disk under this location "C:\Program Files\InfinityBox\Documentation\Unlock_and_repair" Best Regards! yawarniazi |
The Following 3 Users Say Thank You to yawarniazi For This Useful Post: |
08-08-2009, 17:13 | #3 (permalink) |
No Life Poster Join Date: Jan 2008 Location: PAKISTAN KARACHI Age: 44
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | yes i read but its still and plz read logs brother COM3 [VCP0] selected module v2.84 Device: Autodetect 6228-6230 NAND Checking data, wait... Action: erase flash chip Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:EE80:A292 status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... version: 3.02 cpu-id: 0A loader: 3.0840.00.00 NAND id: 98F08095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0200 external ram: 00400000 finalize connection... done ram test... pass 1... pass 2... pass 3... pass 4... done NOR: 0098:004900000000 [01000000] NAND: 0098:00F000800095 [04200000] Initialize Done Set baud ... 921600 Set baud Done Identification ... ram test... pass 1... pass 2... pass 3... pass 4... done reading bootloader structure area (00080000 bytes)... detecting bootloader structure... warning: probably flash chip completely erased, no bootloader found nfi area detection finished: failed warning: can not detect chip parameters, default values assigned Identification Done Write ... formatting... .error: code: 0600006900 .error: code: 1200006900 .......Write Done Finished, time used: 720 sec Remove/Install battery now ! |
12-22-2009, 13:15 | #5 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | kg195 hanging logo i did "LG-KG300_KG200_KG195_repair_freez_restart" this methord but it result is this COM7 [VCP0] selected module v3.02 Device: Autodetect 6228-6229 NAND Checking data, wait... Action: erase NAND flash chip Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:62C1:7D22 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.02 cpu-id: 0A loader: 3.0840.00.00 NAND id: 98F08095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0200 external ram: 00400000 finalize connection... done NOR: 0098:004900000000 [01000000] NAND: 0098:00F000800095 [04200000] Initialize Done Set baud ... 921600 Set baud Done Identification ... ram test... pass 1... pass 2... pass 3... pass 4... done reading bootloader structure area (00080000 bytes)... error: unexpected answer: error: page confirmation is absent, possible data loss ! detecting bootloader structure (chip)... warning: probably flash chip completely erased, no header found nfi area detection finished: failed warning: can not detect chip parameters, default values assigned usb bootloader (chip) is absent Identification Done Write ... formatting... Write Fail Finished, time used: 244 sec Remove/Install battery now |
12-22-2009, 14:03 | #7 (permalink) | |
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Quote:
12-22-2009, 15:55 | #8 (permalink) | |
The Following User Says Thank You to umarmsn For This Useful Post: |
12-24-2009, 09:09 | #13 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, You can flash phone with firmware from support area. At first try to use the same firmware that was installed in your phone before (check operation log of previous operations to see original firmware version). If phone still freez after both format methods and after flashing with firmware from support area - you need to check phone hardware. It may be damaged or bad soldered flash chip. |
12-24-2009, 11:10 | #14 (permalink) | |
12-26-2009, 06:29 | #15 (permalink) | |
can u help to me ."Register mercury" .security area repair ."Code CRC Check Error" what purpose use this options in infinity box.i dont know purpose to options | |
lg kg195 hang after flash dead | XpErTsGsM | Infinity-Box | 10 | 03-11-2011 12:22 |
LG KG195 D/L Singile Program! | simonng83 | LG | 4 | 07-30-2010 19:19 |
kg195 hanging problem logo hang | rameez_gsm | Infinity-Box | 7 | 01-22-2009 14:41 |
LG KG195 off on LG logo. | amol_sm | Infinity-Box | 9 | 06-22-2008 11:44 |
06 Nov 2007: "Hero of India": Spice-S535, Spice-S545, LG-KG195 models supported | InfinitySupport | Infinity-Box | 26 | 01-11-2008 10:17 |
