01-19-2008, 07:54 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: UK
Member: 294200 Status: Offline Sonork: 100.1586184 Thanks Meter: 658 | Lg Kg195 Restart On Startup Screen Thanks in Advance Z.K MOBILES |
01-06-2009, 06:38 | #4 (permalink) | |
Freak Poster Join Date: Mar 2006 Location: peshawar,pakistan
Member: 241705 Status: Offline Thanks Meter: 4,294,967,295 | Quote:
plz infinty team help us thanx alot | |
01-06-2009, 08:54 | #5 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | Quote:
1. Run ChineseMiracle software 2. Select model "MT6228 NAND" 3. Make "format" by "whole flash chip" method i did same methode with LG KG 195 now my set is working very well. here is logs COM13 [VCP0] selected module v2.72 Device: Autodetect 6228, 6229, 6230 NAND Checking data, wait... Action: erase flash chip Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:3941:1B14 high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... version: 3.020A loader: 3.748.0 NAND id: 98F08095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0200 NOR: 0098:004900000000 [01000000] NAND: 0098:00F000800095 [04200000] Initialize Done Set baud ... 921600 Set baud Done Identification ... reading structure area... detecting structure... warning: incorrect bootloader header: 20A898E184DC18E9A0638D19118E74D9 nfi area detection finished: failed error: can't detect nand chip parameters, default values assigned Identification Done Write ... formatting... .error: code: 0A00006900 Write Fail Finished, time used: 885 sec Remove/Install battery now ! I Hope it will help u,,,,BR | |
The Following 5 Users Say Thank You to mobile_hotman For This Useful Post: |
01-05-2010, 09:36 | #6 (permalink) |
No Life Poster Join Date: Sep 2008 Location: karachi
Member: 867259 Status: Offline Sonork: 100.1595961 Thanks Meter: 215 | 1. Run ChineseMiracle software 2. Select model "MT6228 NAND" 3. Make "format" by "whole flash chip" method 4.then select lg and model again And Flash it 5.write eeprom Too Now WorkinG 10000% |
The Following User Says Thank You to nadim_mobiles For This Useful Post: |
03-15-2011, 07:16 | #7 (permalink) | |
No Life Poster Join Date: Feb 2008 Location: +919304287474 Age: 41
Member: 714710 Status: Offline Sonork: offline Thanks Meter: 1,017 | Quote:
lg NTLG1500b Restarting On Startup Screen | Dimortal | VygisToolbox | 18 | 03-03-2011 09:46 |
lg kg195 restart | misbah123 | Infinity-Box | 2 | 08-29-2008 18:50 |
LG KG195 off on LG logo. | amol_sm | Infinity-Box | 9 | 06-22-2008 11:44 |
lg kg195 resart on logo | Mohsin-* | Infinity-Box | 2 | 12-09-2007 11:53 |
Unlocked Z500 restarts on startup | Nicon | QUALCOMM Models (3G) | 4 | 08-07-2005 08:29 |
