04-24-2007, 23:46 | #1 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 241165 Status: Offline Thanks Meter: 2 | lg kg200 help plz i want unlock lg kg200 . it have mini usb port i connect it to my computer usb port and install lg modem driver and it connect with my computer with com 49 but when i want to unlock it with infinity and set port to com 49 . nothing happened for phone ans infinity says' s hold power on key.. how should i connect it to infinity software and unlock it ? BR |
04-25-2007, 00:06 | #2 (permalink) |
No Life Poster Join Date: Jul 2005 Location: I'm back to business
Member: 184793 Status: Offline Sonork: 100.1574609 Thanks Meter: 45 | use kg190/kg200 cable for pinout you can not use usb cable(thinx to mr mobileclinic) Br LordMen007 Last edited by LordMen007; 04-25-2007 at 00:20. |
The Following User Says Thank You to LordMen007 For This Useful Post: |
08-27-2007, 15:05 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! box pinout you can find in our FAQ section: box pin 2- tx box pin 3- rx box pin 8- gnd phone connector pinout you can see in shell.exe selecting model LG KG200. just connect box pins to correspondent pins on phone connector |
08-31-2007, 16:11 | #5 (permalink) |
No Life Poster Join Date: Oct 2003 Age: 43
Member: 40602 Status: Offline Thanks Meter: 118 | i use my own cable and i find it hard to connect the handset. is there anyway to easily connect it i use mmodule 1.57 bau rate : slowest baud autoselect checked use advanced chip checked br, s1emens |
09-01-2007, 04:00 | #7 (permalink) |
Member: 40602 Status: Offline Thanks Meter: 118 | I've searched the pinout it seems to be the same pinout for imobile 510/609/609i cable, am i right? Coz the cable i talked about is hand made, but without any resistor added. Let me try this 1st. That means no specific setting to make the connection easier right? br, s1emens |
09-02-2007, 11:08 | #9 (permalink) |
Member: 40602 Status: Offline Thanks Meter: 118 | still not working, here is the log: COM10 [VCP3] selected Device: LG KG200 Checking data, wait... Action: user code unlock method: standard Boot... Press and HOLD Power button now ! baud autodetection active 9600 Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 8 sec Remove/Install battery now ! already swap rx/tx try to short the rx with tip of the connector but still not working, is there any specific baud rate to ease the connection? br, s1emens |
09-02-2007, 11:17 | #10 (permalink) |
Member: 40602 Status: Offline Thanks Meter: 118 | finally here is the correct setting, use imobile 510 cable but swap rx/tx, baud rate 460800, tick the RTS DTS box, untick Advanced Chip, choose boot baudrate to 10 here is the log: COM10 [VCP3] selected Device: LG KG200 Checking data, wait... Action: user code unlock method: standard Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6219:8B02:8B01]... MT6226MA detected boot step size: 000A Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba TV00578002DABD T 8Mb detecting chip #01 in region #00... flash: 98004900000002:6F736F00000000 flash: Toshiba TV00578002DABD T 8Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Check space... detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [standard] (or higher) generation protocol ver: 04 ver. sw1: ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7S7330TH-001-R1D.BIN ver. sw2: 7S7330TH-001-R1D ffs offset/size: 00E00000/00200000 reading [eeprom[ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7S7330TH-001-R1D.BIN]]... file saved: backup_eeprom[ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7S7330TH-001-R1D.BIN]_20070902-171441.A3E.bin flash: 98004900000002:29EA0000000000 Check space Done Manipulation... detection procedure, wait... detection procedure completed Manipulation Done Finalization... Finalization Done Write... flash: 98004900000002:6F736F00000000 Write: eeprom Write Done Finished, time used: 154 sec Remove/Install battery now ! cheers, br, s1emens |
12-20-2007, 11:43 | #12 (permalink) | |
Freak Poster Join Date: Apr 2005 Location: Ketchery Bazar FSD Pakistan Age: 49
Member: 135718 Status: Offline Thanks Meter: 5 | Quote:
lg ke500 help plz | amanvir | FuriousGold | 4 | 05-17-2008 20:10 |
LG 8360 help plz look & help if you can! | thebrittishguy | LG | 16 | 08-15-2006 08:00 |
The Lg F9100 ?? Help Plz!! | skbleader | Phone Unlocking Codes & Maps | 0 | 01-28-2006 02:49 |
LG U8110 help plz !! | stormt | LG | 1 | 01-11-2006 20:21 |
lg 8120 help plz | gsmone | LG | 0 | 12-20-2004 15:06 |
