Old 03-23-2009, 15:46   #1 (permalink)
meeza_84's Avatar
Member: 279362
Sonork: 100.1594141
Thanks Meter: 500
lg kg200 pinout
i need rj45 pinout for infinity box
i have lg kg200 how remove sequrity code i try but no seusessful
i use cabel g50b
see this log
COM4 [VCP0] selected
module v2.58
Action: read codes
unlock method: read codes
Model: LG-KG200
Checking data, wait...
19200 autodetect
error: boot phase #2/1 failed
Can't initialize test mode !
Possible reasons:
1. communication fault, repeat required operation
2. eeprom/ffs serious damaged, use repair eeprom/ffs files or use other unlock/format method
error: operation failed !
Finished, time used: 6 sec
Remove/Install battery now !
Old 03-23-2009, 17:57   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is an example of information given by Infinity-Box Shell:
Here is information how to build your own cable:
http:///vbb/showthread.php?t=342807
Old 03-23-2009, 17:57   #3 (permalink)
Member: 130995
Hello,
Old 10-22-2009, 08:17   #4 (permalink)
rafi_5217705's Avatar
Member: 627475
Sonork: 100.1594828
Thanks Meter: 1,144
Good posting brother
pinout LG KG200 moie70 LG 24 12-31-2010 17:28
I need lg kg200 pinout z3x Aaman Ali Z3X-Team Products 1 02-18-2010 14:26
LG KG200 LG LOGO Diaplay Only then Off ASHRIFF Infinity-Box 18 10-26-2008 15:14
LG KG200 off on LG startup logo asad_nomy7 Infinity-Box 2 04-09-2008 18:45
Page generated in 0.18794 seconds with 10 queries
