12-03-2008, 09:42 | #1 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 711402 Status: Offline Sonork: 100.1580671 Thanks Meter: 656 | LG KG200 Restart on sim problem then the imei number automatically change 135790246811220 and the oriignal imiei number is 352827011202181 without sim the fone works properly but then on sim its become restart i have also change imei to original format ffs:safe mode but same condition.. what is the solution...... |
12-03-2008, 09:54 | #2 (permalink) | |
Freak Poster Join Date: Sep 2006 Location: Indonesia
Member: 355635 Status: Offline Thanks Meter: 53 | Quote:
try flash eeprom, post result regards notgood | |
12-03-2008, 10:39 | #3 (permalink) |
Member: 711402 Status: Offline Sonork: 100.1580671 Thanks Meter: 656 | COM4 [VCP0] selected Device: LG-KG200 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active "format ffs" active skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6219:8B02:8B01]... CPU: MT6219 CPU: MT6226MA detected chip: 0031:7B41:8DFC boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7S7331RU00-001-R1D.BIN ver. sw2: 7S7331RU00-001-R1D, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7S7331RU00-001-R1D.BIN]... file saved: C:\Program Files\InfinityBox\MModule\eeprom[ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7S7331RU00-001-R1D.BIN]_20081203-143125.A3E.bin Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Area: Eeprom/ffs flash: 98004900000001:29EA0000000000 Write: Eeprom/ffs detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization... formatting... flash: 98004900000001:743E0000000000 Finalization Done Finished, time used: 462 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! after that restart problem solved and new prob SIM card Registration failed... wat is the solution..... |
12-03-2008, 10:44 | #6 (permalink) |
Member: 711402 Status: Offline Sonork: 100.1580671 Thanks Meter: 656 | COM4 [VCP0] selected Action: read codes unlock method: read codes Model: LG-KG200 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6219:8B02:8B01]... CPU: MT6219 chip: 0031:7B41:8DFC CPU: MT6226MA detected Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6219B,E02 Date: 2005.04.12 Version: 1.0 Version: 7S7331RU00-001-R1D Version: EP1 60 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok 208 byte(s) read Phone lock: Off Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 0000 Finished, time used: 11 sec Remove/Install battery now ! i've tried sp-locks but still same prob |
12-03-2008, 10:59 | #8 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
lg kg200 restart in logo need help | shahabuddin | Infinity-Box | 6 | 01-08-2010 13:13 |
how to flash lg kg200/300 on hwk | israrbjr | HWK | 4 | 10-29-2009 03:32 |
LG KG200 off on LG startup logo | asad_nomy7 | Infinity-Box | 2 | 04-09-2008 18:45 |
Tv Y390 Restart On Sim Solved Here | i_am_rocky | Infinity-Box | 0 | 11-02-2007 13:28 |
LG-KG110 Restarts with SIM card | GsmXplorer | Infinity-Box | 1 | 09-26-2007 21:18 |
