04-15-2008, 13:30 | #1 (permalink) |
No Life Poster Join Date: Jun 2006
Member: 303419 Status: Offline Sonork: Fes Thanks Meter: 209 | Lg Kg245 Kiled by Infinity-Box Revived by it's UNBELIEVABLE but believe it 3 days ago I killed lg kg245 by my lovely box "Infinity-Box" it start Flashing but After 8%, Flashing Process Stops I thought It's phone's Hardware Problem but today I Faced The truth when my friend Revive it With H--!--K and without problems!!!!!!! I will Flash it again and then Post the Log here cause now i haven't phone in my hand. thanks infinity-team for U R support |
04-15-2008, 15:11 | #4 (permalink) | |
No Life Poster Join Date: Jan 2005 Location: E G Y P T Age: 48
Member: 102762 Status: Offline Sonork: 1583079 Thanks Meter: 186 | Quote:
what do u mean by "hwk is very weak in lg"? do u mean that hwk had some kind of illness i mean headache for ex? ptw hwk requires afull charged battery in all opertions that can be done to lg phones i donot mean that infinity is abad tool or that hwk is better than it or vice versa but what i mean u can do agood job if u know how to use the correct tool with the correct model | |
04-15-2008, 18:15 | #6 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: algeria BBA BELIMOUR Age: 46
Member: 184351 Status: Offline Thanks Meter: 263 | Quote:
ps :sorry to the supporter for the wrong section | |
06-29-2008, 21:38 | #8 (permalink) |
Insane Poster Join Date: Nov 2005
Member: 196054 Status: Offline Thanks Meter: 7 | same problem stop flashing at 8 % this is the log when flashing with lastest version COM11 ready Testing COM11 at 115200... COM11 [VCP0] selected Device: LG KG245 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" enabled "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 0000527A Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 350305260000001 current otp imei: 359103000654961 file saved: C:\Program Files\InfinityBox\LGA\eeprom_350305260000001_LG KG245_20080626-173613.B1E.bin .......... version: ***-XXV10fWEUKG245P64 Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) calibration area skipped flash: 01227E223C2200:FEEA0000000000 error: no any expected answer error: flash write error: 01080000:00040000 Write Fail Finished, time used: 55 sec Remove/Install battery now ! please help |
06-29-2008, 21:45 | #9 (permalink) |
Member: 196054 Status: Offline Thanks Meter: 7 | but when i flash it with 1.25 version withe the firmware from support it finish flashing but don't power on and tis is the log .: Application: C:\Program Files\InfinityBox\LgA\LgA.exe Loading data, wait... [Infinity Box] v1.25 S/N: 3B22:010F Wait... Current device: LG B2000 Done Current device: LG KG245 Loading file v.02... KG245P64-07-V10k-***-XX SEP 26 2006_CodeData_w_calibration.B1M.bin loaded Loading file v.02... KG245P64-07-V10k-***-XX SEP 26 2006_AlchemyData.B1P.bin loaded Testing COM11 at 921600... COM11 [VCP0] selected Device: LG KG245 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" enabled "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 0000527A Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 350305260000001 current otp imei: 359103000654961 file saved: C:\Program Files\InfinityBox\LgA\backup_eeprom_35030526000000 1_LG KG245_20080629-213800.B1E.bin .................................................. .............. Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) calibration area skipped flash: 01227E223C2200:FEEA0000000000 Write: Alchemy data flash: 01227E223C2200:FFFFFF00000000 Write Done Finished, time used: 673 sec |
06-30-2008, 22:32 | #13 (permalink) |
Freak Poster Join Date: Aug 2005 Location: PH Age: 47
Member: 167930 Status: Offline Thanks Meter: 5 | hahaha thats why its necessary to have more box so you know where to rely on different phone and situation...and dont shout at here go @hwk support & rejoice there sumtyms some box really s*cks.. |
06-30-2008, 22:57 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @GyRO if you want to talk about technical problems you can talk about it here if you want to talk about HWK please go to HWK section if you want to talk about nothing it's better to go to "offtopic" forum section let's respect each other and not post strange offtopic messages in Infinity-Box support forum |
another lg kp235 unlock ok by infinity box | genci titi 2002 | Infinity-Box | 3 | 04-02-2010 11:54 |
lg kp 100 unlock ok by infinity box | aleem26 | Infinity-Box | 20 | 09-07-2009 21:48 |
LG-KG245 unlocked with infinity | topnoyze | Infinity-Box | 2 | 02-10-2009 07:05 |
lg kp130 unlock ok by Infinity box | aleem26 | LG | 2 | 09-06-2008 11:37 |
Korean Samsung, LG supported by Infinity box ? | tian | Infinity-Box | 1 | 06-10-2008 20:32 |
