09-24-2010, 11:20 | #1 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Skopje, Macedonia Age: 36
Member: 472933 Status: Offline Sonork: 100.1590967 Thanks Meter: 1,331 | Vodafone 541 a.k.a. AlcOT708 - warning: wrong data size at 0x0004C440, retry... Quote:
i have many unlocked but this is totaly new branded phone and don't wanna to unlock. | |
09-24-2010, 12:22 | #2 (permalink) |
Member: 472933 Status: Offline Sonork: 100.1590967 Thanks Meter: 1,331 | with lower speed - sucesfull COM11 [VCP0] selected module v3.51 Device: Alcatel-708X, 708A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:7E03:A001 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 230400 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.0DCB0 779.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_064A906B].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 0DCB0779 rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, 6B904A06 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 17C provider: 708X-2EVDMK1 customization: CN17FW80 customization: XN17FW80 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN17FW80 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN17FW80 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35908103290378 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-708X,708A_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_0 8A_W08_40_SP1_V32__system_log_0DCB0779_064A906B_20 100924-132041.B0X.bin Finished, time used: 5 min 10 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to Boshko_Alfa For This Useful Post: |
09-24-2010, 16:04 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, I think this error may be a result of errors during communication, it may be a result of phone hardware or f.e. due to quite long cable wires. |
Data cable | Aldrin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-26-2000 14:06 |
cellular data suite kabel | vingis | Main Sales Section | 0 | 11-25-1999 19:18 |
The Best Dual Data cable FBUS-M2BUS for your NOKIA 5110 6110 | Nk_Cable | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-10-1999 10:08 |
Cellular Data Suite Cables avaliable !!! | vingis | Main Sales Section | 0 | 11-02-1999 17:35 |
The Best Dual Data cable FBUS-M2BUS for your NOKIA 5110 6110 | nk.cable | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-14-1999 15:33 |
