Old 11-26-2008, 08:51   #1 (permalink)
3stanGsm's Avatar
Member: 331390
Thanks Meter: 433
LG KG270 Sim Card Error Solution
LG KG270 Sim Card Error Solved!
just unlock it with AIRTEL MODE.
COM7 [VCP0] selected
Device: LG-KG270
Checking data, wait...
Action: unlock
direct unlock method #2 (Airtel etc.)
Boot...
Press and HOLD Power button now (if boot does not start remove/install batery) !
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud...
921600
Set Baud Done
Connecting...
flash: 0001:011A
Connecting Done
Check hardware...
sw version: ULC2GL GLOBE KG270 P16 FL 63 V10b 515-02 MAY 09 2007 +0
Check hardware Done
Check parameters...
Check parameters Done
backup critical area...
reading [eeprom-sta]...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-sta_20081126-160507.B1E.bin
loading data...
data loaded
imei: 35744501096189000
reading [eeprom-sec_35744501096189000]...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-sec_35744501096189000_20081126-160508.B1E.bin
reading [eeprom-complete_35744501096189000]...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-complete_35744501096189000_20081126-160510.B1E.bin
backup critical area Done
Check memory...
Check memory Done
Write...
Erasing: eeprom-sec
Writing: eeprom-sec
probably you need to restore original imei after unlock process
Write Done
Finished, Remove/Install battery now !
Time used: 17 sec
The Following 4 Users Say Thank You to 3stanGsm For This Useful Post:
Old 11-26-2008, 08:54   #2 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,016
yes tested also with KG288 successfully.
The Following 2 Users Say Thank You to asad_nomy7 For This Useful Post:
Old 12-21-2008, 14:40   #3 (permalink)
tom313rd's Avatar
Member: 436045
Sonork: 1581208
Thanks Meter: 31
Hello every1
Jus to add some useful info in this thread i'd say i tried kg276 wiv the same solution..
but it didnt work for me. The fone wasnt actually accepting all sims.
Later i found out that the IMEI was blocked.
So if unlocking doesnt help u get rid of SIMCARD ERROR..
It is worth changing IMEI...
Worked for me 100%
Br,
TOm @ Future Fones
The Following User Says Thank You to tom313rd For This Useful Post:
Old 12-04-2009, 05:55   #4 (permalink)
Member: 713374
Sonork: 100.1597179
Thanks Meter: 222
would u plz tell how to unokc it with air tel mode..im not getting that tnx
Old 12-04-2009, 06:21   #5 (permalink)
Member: 713374
Sonork: 100.1597179
Thanks Meter: 222
i did it wid ufs hwk...
just rebuild imei...or bring changes...then unlock .....
so it will workible...
Old 12-04-2009, 12:23   #6 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,397
Hello,
Go to software "Service" page.
Select "unlock method #2"
Make "sp-unlock"
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post:
Old 04-16-2011, 11:15   #7 (permalink)
Crazy Poster
Member: 354074
Thanks Meter: 18
lg kg288 simcard error
sp unlock phone succe
KG270 sim card error asrar LG 15 07-22-2010 12:49
Lg kg270 sim ways - final solution cel_phon Nokia Hardware & Hardware Repair 7 11-03-2009 08:58
Lg kg270 sim ways - final solution cel_phon LG Hardware Repair 3 07-05-2009 16:03
Lg kp100 sim card error repair done by polar:::ENJOY::: FullFLASHgSMPH PolarBox 3 1 01-11-2009 02:16
LG k275 Sim Card Error solution claudeoscar LG 0 09-10-2008 05:55
Page generated in 0.33080 seconds with 8 queries
