Old 10-28-2008, 12:57   #1 (permalink)
mohd aji's Avatar
Member: 202201
Thanks Meter: 21
lg kg275 blinking
phone was showing signal problem after flash but after writing eprom file it starts blinking i have tried all available eprom available at support but no solution yet.....
Old 10-28-2008, 13:31   #2 (permalink)
gujjar_brothers's Avatar
Member: 558087
Sonork: 100.1579413
Thanks Meter: 332
another phone read eeprom then write to signal problem phone ,,,
Old 10-28-2008, 13:39   #3 (permalink)
mohd aji's Avatar
Member: 202201
Thanks Meter: 21
bro i dont have got kg275 from which i read that file if somone have give me please although thanks for reply...........
Old 10-28-2008, 14:07   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Just make sp-unlock by different methods, phone should be Ok.
Old 10-28-2008, 15:04   #5 (permalink)
mohd aji's Avatar
Member: 202201
Thanks Meter: 21
Thanks to infinity for quick reply blinking problem solved by unlock method 2 but when i make a call phone shows call disconnected
Old 10-28-2008, 15:19   #6 (permalink)
Member: 130995
Hello,
Check phone imei and repair it if need.
Old 10-28-2008, 15:59   #7 (permalink)
mohd aji's Avatar
Member: 202201
Thanks Meter: 21
phone imei cant repair and shows an error.....
Phone must be SWITCHED ON !
Connecting, wait...
Connection Ok
Repair imei...
software version: KG270P16-07-V10h-XXX-XX-JAN 24 2008+0
original imei: 35744501217708100
new imei: 35744501125469
error: imei verification failed, try again.
Done
Finished
Old 10-28-2008, 16:39   #8 (permalink)
Member: 130995
Hello,
As I can see phone imei can be accepted by network.
Did you tried to make 112/emergency call without sim card ?
If phone can not make emergency call it may be phone hardware fault, also this fault was before flashing so I think you need to check phone hardware.
Old 10-28-2008, 17:01   #9 (permalink)
mohd aji's Avatar
Member: 202201
Thanks Meter: 21
yes boss phone is dialling 112 and now phone is on searching
Old 10-28-2008, 17:06   #10 (permalink)
Member: 130995
Hello,
Sorry did not understand well.
Can you make 112 call well or you have a problems with 112 call ?
Old 10-28-2008, 17:11   #11 (permalink)
mohd aji's Avatar
Member: 202201
Thanks Meter: 21
bro phone is making call on 112
Old 10-28-2008, 18:06   #12 (permalink)
Member: 130995
Hello,
You can try to use another eeprom files and make unlock after each new eeprom file.
Also you can try to use other firmware.
Old 10-28-2008, 19:28   #13 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
Exclamation
always make a eeprom backup during formating flashing or any operation.
Old 11-11-2008, 11:23   #14 (permalink)
barani's Avatar
Member: 165982
Thanks Meter: 71
Originally Posted by InfinitySupport View Post
Hello,
method working 100% sir,thanks to infinity
UNLOCK LG KG275 with Vygis? PEREPELKINE LG 3 09-07-2007 14:39
Lg Kg275 tassili LG 1 08-31-2007 14:38
urgent help please LG KG275 yane VygisToolbox 1 08-14-2007 17:45
how to unlock lg kg275 ??? jokkergsm Infinity-Box 8 08-07-2007 12:11
Lg Kg275!!! youcgsm LG 0 07-31-2007 14:45
Page generated in 0.26471 seconds with 9 queries
