Old 01-18-2009, 15:28   #1 (permalink)
Member: 271980
Sonork: 100.1573370
Thanks Meter: 227
LG KG275 Unlocked sucessfully
COM3 [VCP0] selected
module v1.60
Device: LG-KG275
Checking data, wait...
Action: unlock
direct unlock method #2 (Airtel etc.)
Boot ...
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
sw version: .00 ULC2GL ORANGE FR KG275 P16 FL 33 V10b 208-01 JUN 08 2007 +1
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG275_eeprom-static_20090118-172724.B1E.bin
loading data...
data loaded
imei: 35858201013715100
reading eeprom-security_35858201013715100...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG275_eeprom-security_35858201013715100_20090118-172725.B1E.bin
reading eeprom-complete_35858201013715100...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG275_eeprom-complete_35858201013715100_20090118-172726.B1E.bin
backup critical area Done
Check memory ...
Check memory Done
Write ...
Erasing: eeprom-security
Writing: eeprom-security
probably you need to restore original imei after unlock process
Write Done
Finished, time used: 19 sec
Remove/Install battery now !
The Following User Says Thank You to kabo tel For This Useful Post:
Old 01-18-2009, 16:05   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works and what is
possible problems (so we will be able to fix it) and successfully done work.
Lg kg275 unlock problem. haber Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 4 09-24-2008 14:29
lg kg275 unlocking error... reimon23 Infinity-Box 19 08-31-2008 20:20
LG KG275 unlock brahim12 Multi-Box 6 04-29-2008 20:13
LG KG275 unlocking problem Faheem Anjum FuriousGold 18 03-16-2008 20:23
LG KG275 unlocks needed thechachman Phone Unlocking Codes & Maps 0 12-28-2007 09:51
Page generated in 0.16658 seconds with 9 queries
