04-22-2009, 12:43 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | LG KG275 Unregestered sim card problem LG KG275 Unregistered sim card problem...........imei is mismatch i try to repair imei proccess ok but problem is same ......i flash it then writ repair eeprom file but now set be gain to restart ...........there is 9 eeprom files i flash with every one but set still restarting.........what is the solution please |
04-22-2009, 13:55 | #4 (permalink) |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | Bro it is as simple as 1234 just type new IMEI n write IMEI by infinity_Software n u r done.. C LOGS Phone must be SWITCHED ON ! Connecting, wait... Connection Ok Action: imei software version: KG275P16FL-44-V10a-234-33-AUG 17 2007+0 original imei: 35558801055297900 new imei: 35556601033297 imei verification Ok Done Finished Br |
04-22-2009, 14:24 | #5 (permalink) | |
No Life Poster Join Date: Feb 2008 Location: Dubai
Member: 703206 Status: Offline Sonork: 100.1601193 Thanks Meter: 412 | Quote:
direct unlock method #1 if not work then direct unlock method #2 (Airtel etc.) 100% working with Unregistered sim card i have don many kg270 or 75 | |
04-22-2009, 14:49 | #6 (permalink) | |
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | Quote:
04-22-2009, 16:45 | #7 (permalink) | |
Member: 214340 Status: Offline Thanks Meter: 906 | Quote:
BR | |
04-22-2009, 17:25 | #8 (permalink) |
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | bro.........i have already flashed with different vers but problem is same .......need help from infinity team why they are mum |
04-23-2009, 15:27 | #10 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Larkana Sindh Pakistan Age: 40
Member: 600691 Status: Offline Thanks Meter: 29 | Originally Posted by zeerik bro ...i did as you said ..........but there is strange problem .... when i write the imei from back side and press write all is ok .....but when i check *#06# the imei still mismatch and still unregistered message ...i try to chang imei but facing "imei verification error" it means the problem in eeprom file .........if i am right then please upload here an working eeprom file because all the 9 eeprom files in infinity support area not working for me with them phone begain to blin same problam with my kp100 set |
04-23-2009, 16:13 | #11 (permalink) | |
No Life Poster Join Date: Nov 2002 Location: Slovakia Age: 40
Member: 17405 Status: Offline Thanks Meter: 345 | Quote:
1. Flash phone with flash from support 2. Flash eprom: KG275_repair_eeprom_08.B1E.bin 3. Direct Unlock Method 2 4. Read Unlock code 5. Enter Unlock code with non accepted sim card 6. Repair IMEI | |
04-23-2009, 22:35 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @zeerik 1. Did you tried to write repair eeprom files from support area and then repair imei ? What is the results ? 2. Did you tried to make 112/emergency call without sim card ? What is the results ? |
::who want solution for lg ku380 insert sim card problem??:: | toutou_gsm | LG Hardware Repair | 56 | 02-06-2013 10:41 |
V9 unlock successful test card use ok but gsm sim card problem | rokon | Motorola P2k | 0 | 01-11-2010 17:53 |
Sim card problem, only reads 64k sim cards | nost | Nokia Hardware & Hardware Repair | 4 | 08-20-2009 01:22 |
LG KU380 Insert Sim Card Problem | marcsantos | LG | 1 | 08-13-2009 09:13 |
Lg Kg275 Unauhorized Sim | dil_PAKISTANI | Infinity-Box | 7 | 02-17-2008 14:44 |
