Old 10-07-2008, 15:36   #1 (permalink)
zeel_zeel's Avatar
Member: 205427
Sonork: 100.1580937
>>> LG KG276 Unlocked Successfully <<<
Infinity unlocked a LG KG276 (BSNL) with charm. Direct unlock method 2 (Airtel etc) was used to unlock it...
Also do not forgot to repair the imei after unlock procedure..
Thanks Infinity Team >>>>
COM5 [VCP0] selected
Device: LG-KG276
Checking data, wait...
Action: unlock
direct unlock method #2 (Airtel etc.)
Boot...
Press and HOLD Power button now (if boot does not start remove/install batery) !
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud...
921600
Set Baud Done
Connecting...
flash: 0001:011A
Connecting Done
Check hardware...
sw version: ULC2GL BSNL KG271 P16 FL 91 V10a 404-66 JAN 29 2008 +0
Check hardware Done
Check parameters...
Check parameters Done
backup critical area...
reading [eeprom-sta]...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG276_eeprom-sta_20081006-153248.B1E.bin
loading data...
data loaded
imei: 35617601968825600
reading [eeprom-sec_35617601968825600]...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG276_eeprom-sec_35617601968825600_20081006-153251.B1E.bin
reading [eeprom-complete_35617601968825600]...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG276_eeprom-complete_35617601968825600_20081006-153304.B1E.bin
backup critical area Done
Check memory...
Check memory Done
Write...
Erasing: eeprom-sec
Writing: eeprom-sec
probably you need to restore original imei after unlock process
Write Done
Finished, Remove/Install battery now !
Time used: 32 sec
Loadng data, wait...
Phone must be SWITCHED ON !
Connecting, wait...
Connection Ok
Repair imei...
software version: KG276P16FL-91-V10a-404-66-JAN 29 2008+0
original imei: 35617601968825600
new imei: 35617601968825
imei verification Ok
Done
Finished
The Following 2 Users Say Thank You to zeel_zeel For This Useful Post:
Old 10-07-2008, 19:28   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thank you very much for test report !
Each test report with attached logs is very important for us so we can see how is Infinity-Box
software works and what is possible problems and successfully done work.
Old 01-31-2009, 04:17   #3 (permalink)
Member: 101650
yes i tested this ,this is very useful post .i tried many times to unlock sp lock it done successfully everytime but no other sim works, it works after changing imei......
>>> LG KU990 Unlocked Successfully <<< cellcarekphb Easy-Unlocker 5 02-11-2009 17:40
>>> LG CU920 Unlocked Successfully <<< zeel_zeel Easy-Unlocker 1 02-05-2009 08:58
>>> LG KP235 unlocked Successfully <<< zeel_zeel Infinity-Box 2 09-17-2008 18:02
>>> LG CU500v unlocked successful <<< zeel_zeel FuriouS TeaM Products 6 09-11-2008 06:40
>>> LG KG130 unlocked success <<< zeel_zeel Infinity-Box 4 08-25-2008 06:46
Page generated in 0.23979 seconds with 11 queries
