03-14-2008, 16:51 | #1 (permalink) |
Freak Poster Join Date: Dec 2006
Member: 407316 Status: Offline Thanks Meter: 78 | LG KG290 dead after unlocking Here's the log file from trying to load the backup : COM9 [VCP0] selected Device: LG KG290 Checking data, wait... advanced flash detection active Action: flash write Skip: Firmware (code) Skip: File system Skip: Alchemy data Write: Eeprom "smart write" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud... 115200 Set baud Done Check flash... file saved: F:\Program Files\InfinityBox\LGA\backup_eeprom__LG KG290_20080315-154910.B1E.bin .............. Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Eeprom flash: 89881600010001:89881600000000 Write Done error: wrong answer[C5] Finished, time used: 49 sec Remove/Install battery now ! |
03-14-2008, 17:59 | #3 (permalink) |
Member: 407316 Status: Offline Thanks Meter: 78 | Yes, before trying unlock the phone was working normally, when unlocking the phone, infinity gave a warning that the phone is wrong model or the eprom structure is unknown, as I was busy with other phone I've ignored it and pressed Yes, after that he started with the process but in the middle it gave a problem with writing the flash, after few retries i gave up. What can I do to bring it back to live? The log that I've put is the one from trying to load a backup file. |
03-14-2008, 18:05 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Please, send "operation.log" file to [email protected] |
03-18-2008, 21:02 | #5 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Romania Brasov Age: 46
Member: 25136 Status: Offline Sonork: 1591036 Thanks Meter: 54 | Device: LG KG290 Checking data, wait... advanced flash detection active Action: unlock unlock method: enhanced Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 357456013892990 file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_35745601389299 0_LG KG290_20080318-210205.B1E.bin .... Check flash Done Check space... current eeprom imei: 357456013892990 Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 error: no any expected answer error: flash write error: 01000000:00008000 error: no any expected answer error: flash write error: 01000000:00008000 error: can't write lock area Write Fail Finished, time used: 67 sec Remove/Install battery now ! Wen i try flash backup eprom : Device: LG KG290 Checking data, wait... advanced flash detection active Action: flash write Skip: Firmware (code) Skip: File system Skip: Alchemy data Write: Eeprom "smart write" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud... 115200 Set baud Done Check flash... file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom__LG KG290_20080318-212700.B1E.bin .... Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Eeprom flash: 89881600010001:89881600000000 error: no any expected answer error: flash write error: 01000000:00008000 error: no any expected answer error: flash write error: 01000000:00008000 error: no any expected answer error: flash write error: 01000000:00008000 Write Fail Finished, time used: 110 sec Remove/Install battery now ! |
03-18-2008, 21:09 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @sdr What is phone state now ? Please, send backup_eeprom_35745601389299 0_LG KG290_20080318-210205.B1E.bin to [email protected] Also tell me your e-mail, I'll send you new software for test. |
03-18-2008, 21:15 | #7 (permalink) |
Member: 25136 Status: Offline Sonork: 1591036 Thanks Meter: 54 | Solvet with version 2.6 from infinity Device: LG KG290 Checking data, wait... advanced flash detection active Action: flash write Skip: Firmware (code) Skip: File system Skip: Alchemy data Write: Eeprom "smart write" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud... 921600 Set baud Done Check flash... file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom__LG KG290_20080318-221202.B1E.bin .... Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Eeprom flash: 89881600010001:89881600000000 Write Done error: wrong answer[C1] Finished, time used: 21 sec Remove/Install battery now ! |
LG 8360 dead after unlock | ghibli | FuriouS II | 1 | 04-05-2006 17:46 |
Help Lg 8120 Dead After Unlocking | FREETHEMOBLIE | Hardware Repair by brands | 1 | 11-27-2005 17:25 |
lg 8110 dead after unlock on samart dongle | CELL SOLUTIONS | SonyEricsson (USB-Smart) | 3 | 09-23-2005 19:38 |
lg 8330 dead after unlock | STOMATELA | VygisToolbox | 10 | 07-06-2005 07:38 |
lg c3100 dead after unlock HELP PARDEF OF JULVIR PLS!! | david69 | Redbox | 19 | 04-18-2005 09:14 |
