08-10-2008, 14:43 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: SBZ-TUNISIA Age: 54
Member: 104036 Status: Offline Thanks Meter: 44 | Lg Kg290 Flashing ?? this is sreen from infinity after many tries at diff baud rate .... rehot pcb .... no chance so i decide to use free downloader and at my great surprise phone erased and revived ok and this some screen shoot may be infinity have to review erase and flash algo for this phone |
08-11-2008, 21:06 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Thank you very much for information ! We will check what can be the problem. Btw, did you tried to flash phone with Infinity-Box again after PCB rehot ? |
08-12-2008, 16:11 | #3 (permalink) | |
Member: 104036 Status: Offline Thanks Meter: 44 | Quote:
same after flash with multiloader and phone ok then with infinity same problem no pssibility to complete flash just stop at 7% just one mention with multiloder must keep power press until erase bar progress otherwise cant complete process and get failed !!! | |
09-02-2008, 21:29 | #5 (permalink) |
Freak Poster Join Date: May 2006 Location: SUDAN Age: 39
Member: 271980 Status: Offline Sonork: 100.1573370 Thanks Meter: 227 | i have same problem now u can flash firmware full by LgA 1.25 now the problem in Alchemy data stoped in 10% COM3 [VCP0] selected Device: LG KG290 Checking data, wait... advanced flash detection active Action: flash write Skip: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 357456012407089 file saved: C:\Program Files\InfinityBox\LgA\backup_eeprom_35745601272179 4_LG KG290_20080902-215612.B1E.bin .............. Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Alchemy data flash: 89881600010001:89881600000000 error: no any expected answer error: flash write error: 04020000:00020000 Write Fail Finished, time used: 180 sec Remove/Install battery now ! i am tryed by all lga software plz infinity team reslove problem |
09-03-2008, 17:11 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, use latest LgA module from support area and try to flash your phone again (select model KP230, use KG290 flash files). Waiting for your results. |
LG - KG290 flashing error | Dilip_Nath | Infinity-Box | 33 | 03-11-2011 18:57 |
need lg kg290 flash file or link urgent | aukonline | FuriousGold | 18 | 01-20-2010 08:21 |
lg kg290 flashing problem | zinhom | Infinity-Box | 1 | 09-28-2008 23:02 |
lg kg290 flash prob | habibkhalil | Infinity-Box | 2 | 06-01-2008 15:00 |
