LG - KG290 flashing error LG - KG290 flashing error Hello everybody, when I try to flash a LG, which model is KG290, its show me error.......... heres the log. ------------------------------------------- COM14 [VCP0] selected module v1.35 Device: LG-KG290 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" enabled "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud... 460800 Set baud Done Check flash... current eeprom imei: 357456017542500 file saved: C:\Program Files\InfinityBox\LGA\eeprom_357456017542500_LG-KG290_20081115-161028.B1E.bin .............. Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) calibration area skipped flash: 89881600010001:89881600000000 Write: Alchemy data flash: 89881600010001:89881600000000 error: no any expected answer error: flash write error: 04020000:00020000 error: no any expected answer error: flash write error: 04020000:00020000 Write Fail Finished, time used: 106 sec Remove/Install battery now ! --------------------------------------------- Please let me know what should I do? wbr Dilip |
Do infinity can't solve it? Infinity team please answer me. with thanks. Dilip |
check batry must be charged .and try again. ;) |
@Dilip_Nath What was with phone before flashing ? |
same here man need solution please..... |
@Dilip_Nath So now phone after flashing is the same condition like before flashing ? @spinbaaz.com What is the problem exactly ? |
No, phone dont get full flash.......... If you see log, you will be clear. I want to clear that, I cant flash KG290, by Infinity.......... The phone condition is hang with logo. Thanks for reply. |
Brother battery fully charged but problem not solve....... it dosen't take flash. Any idea. wbr Dilip |
Hello, Yes, I have checked log very carefully before ask my questions. So, please, give me an answers: What is phone condition now ? Is it the same condition like before flashing ? |
hello man me do that with phine when arabic it turn with me ti 7% and stoped that is give me small problem im my job i thing! ou need uest fuiros gold |
please help. wbr Dilip |
Hello, We will try to check what can be the problem (if any). For now you can try to write only Alchemy flash part by selecting KP202 model. Waiting for your results. |
When I try to flash Alchemy flash part by setecting KP202 instead of KG290, the phone doesn't boot. wbr Dilip |
At last I flash phone by selecting KG290...................... Here's my flashing log........... ===================================== COM14 [VCP0] selected module v1.35 Device: LG-KG290 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" enabled "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud... 230400 Set baud Done Check flash... current eeprom imei: 350305260000001 file saved: C:\Program Files\InfinityBox\LGA\eeprom_350305260000001_LG-KG290_20081118-142337.B1E.bin .............. Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) calibration area skipped flash: 89881600010001:89881600000000 Write: Alchemy data flash: 89881600010001:89881600000000 Write Done Finished, time used: 65 sec Remove/Install battery now ! ------------------------------------------ COM14 [VCP0] selected module v1.35 Device: LG-KG290 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" enabled "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud... 230400 Set baud Done Check flash... current eeprom imei: 350305260000001 file saved: C:\Program Files\InfinityBox\LGA\eeprom_350305260000001_LG-KG290_20081118-142856.B1E.bin .............. Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) calibration area skipped flash: 89881600010001:89881600000000 Write: Alchemy data flash: 89881600010001:89881600000000 Write Done Finished, time used: 65 sec Remove/Install battery now ! ----------------------------------------------------- But now phone is blinking continuously. I try to flash another firmware but show write error. Please guide me. wbr Dilip |
