Old 04-06-2009, 17:20   #1 (permalink)
ARS.Rehman's Avatar
Member: 491455
Sonork: On My LAB
Thanks Meter: 280
LG KG290 Flashing Error
Any Idea for this error
And
When I Load Backup Frimware.
Always Show This error "Bad data"
Old 04-06-2009, 17:49   #2 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Dear this is not show Bad data.
This problem comes through battry.
Full charged u r battry & properly Fix the battry to the set & try again.
Do not louse grip on the battry.
Last edited by amol_sm; 04-06-2009 at 17:53. Reason: Bad data doesn't show in the image.
Old 04-06-2009, 18:26   #3 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,401
@ARS.Rehman
Please, download and install LgA v1.22 or v1.24 module from /software/archive folder and flash phone again.
Old 04-07-2009, 10:22   #4 (permalink)
azeem781986's Avatar
Member: 503161
Sonork: 100.1584069
Thanks Meter: 470
Originally Posted by InfinitySupport View Post
@ARS.Rehman
any one who test this plz post logs
thanks
AzeeM
Old 04-07-2009, 11:14   #5 (permalink)
Member: 130995
@azeem781986
if you have a problem with phone you can test this solution by yourself.
Old 04-07-2009, 12:02   #6 (permalink)
Member: 503161
Sonork: 100.1584069
Thanks Meter: 470
.::Tested with my kg290::.
@azeem781986
yes i hav tested it
1.i didnt find LGA 1.22 on support
I found LGA 1.24 and then made flash operation
during flash with 1.24 firmware was sucessfully written but gives error while writing alchemy data
2.Then i downloaded 1.26 also gave error both on firmware and alchemy..
3.The next i downloaded 1.29 it wrote complete firmware and alchemy data but gives this error plz help me my LG KG290 is on logo still and after few second blink...
i also wrote eeprom callibration
kindly suggest me powerful solution
here is the log i get this error with all speeds set from settings
COM3 [VCP0] selected
Device: LG KG290
Checking data, wait...
advanced flash detection active
Action: flash write
Write: Firmware (code)
Skip: File system
Write: Alchemy data
Write: Eeprom
"smart write" enabled
Boot...
Phone must be POWERED-OFF !
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: 89881600010001:89881600000000
flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb
Boot Done
Set baud...
460800
Set baud Done
Check flash...
current eeprom imei: 355968855966965
file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_35596885596696 5_LG KG290_20090407-024834.B1E.bin
Check flash Done
Check space...
Check space Done
Check parameters...
Check parameters Done
Erase...
Erase Done
Write...
Write: Alchemy data
Write: Eeprom
flash: 89881600000000:89881600000000
Write Done
error: wrong answer: C5
Finished, time used: 67 sec
Remove/Install battery now !
thanks in advance
The Following User Says Thank You to azeem781986 For This Useful Post:
Old 04-07-2009, 20:00   #7 (permalink)
Member: 130995
Hello,
If you talk about this error:
it's not important and do not affect to phone functionality.
What was with phone before flash operation ?
Old 04-07-2009, 21:52   #8 (permalink)
Member: 503161
Sonork: 100.1584069
Thanks Meter: 470
i took the fone from customer it was on kg290 logo still and after few seconds it blinks and same position is now with it no effect
done everything i could with infinty box:
Old 04-07-2009, 22:37   #9 (permalink)
Member: 130995
@GSM-XPERTS
Here is Infinity-Box support forum but not discussion about anything else. Please, next time select correct thread.
offtopic message was deleted
Old 04-08-2009, 14:34   #10 (permalink)
ARS.Rehman's Avatar
Member: 491455
Sonork: On My LAB
Thanks Meter: 280
Thanks For Good help Infinity team!
LG - KG290 flashing error Dilip_Nath Infinity-Box 33 03-11-2011 18:57
Lg Kg290 Flashing ?? youssef70 Infinity-Box 11 04-20-2009 14:14
lg kg290 flashing problem zinhom Infinity-Box 1 09-29-2008 00:02
lg kg290 flash prob habibkhalil Infinity-Box 2 06-01-2008 16:00
Lg KG290 unlock error Akili Bulent Infinity-Box 3 10-21-2007 20:31
Page generated in 0.32787 seconds with 9 queries
