Old 03-02-2008, 21:05   #1 (permalink)
Registered User
Member: 34599
Thanks Meter: 12
LG KG290 with lgv1.27 still error
this is my log:
Phone must be POWERED-OFF !
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: 89881600010001:89881600000000
flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb
Boot Done
Set baud...
921600
Set baud Done
Check flash...
file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom__LG KG290_20080303-035531.B1E.bin
Check flash Done
Check space...
Check space Done
Check parameters...
Check parameters Done
Erase...
Erase Done
Write...
Write: Firmware (code)
calibration area skipped
error: no any expected answer
error: flash write error: 01010000:00008000
Write Fail
Finished, time used: 73 sec
Remove/Install battery now !
phone problem is when i press power button just show lgkg290 and off again..
br...?
Old 03-02-2008, 21:42   #2 (permalink)
Registered User
Member: 34599
Thanks Meter: 12
when im use v 1.27 my phone become dead..
and im use v1.26 flash work but still error...
but my lg kg 290 alive again.
just show lg kg290.
Old 03-02-2008, 21:51   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Try to flash phone at 115200 baud but not at 921600.
Alos be sure that battery is enough charged.
What was initial phone state ?
Old 03-03-2008, 01:56   #4 (permalink)
Registered User
Member: 34599
Thanks Meter: 12
still same problem with 115200 speed baudrate.
Testing COM7 at 115200...
COM7 [VCP4] selected
Device: LG KG290
Checking data, wait...
advanced flash detection active
Action: flash write
Skip: File system
Write: Alchemy data
Skip: Eeprom
"smart write" enabled
Boot...
Connecting, wait...
Boot Done
Set baud...
115200
Set baud Done
Check flash...
file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom__LG KG290_20080303-035242.B1E.bin
Check flash Done
Check space...
Check space Done
Check parameters...
Erase...
Erase Done
Write...
error: flash write error: 01000000:00008000
Write Fail
Finished, time used: 47 sec
Old 03-03-2008, 02:42   #5 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
Also be sure that battery is enough charged.
Old 03-04-2008, 17:36   #6 (permalink)
Member: 92527
hello!
COM2 [VCP3] selected
Device: LG KG290
Action: flash write
Skip: File system
Write: Alchemy data
Skip: Eeprom
"keep calibration" enabled
Boot...
Connecting, wait...
Boot Done
Set baud...
115200
Set baud Done
Check flash...
current eeprom imei: 357456011748681
file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_35745601174868 1_LG KG290_20080304-182512.B1E.bin
Check flash Done
Check space...
Check space Done
Check parameters...
Erase...
Erase Done
Write...
Write Fail
Finished, time used: 46 sec
Old 03-04-2008, 18:54   #7 (permalink)
Member: 130995
Hello,
We will double check software.
Old 03-14-2008, 12:43   #8 (permalink)
Member: 407316
Thanks Meter: 78
I have the same problem, phone is dead, what can I do about it?? Pls help
Old 03-14-2008, 18:16   #9 (permalink)
Registered User
Member: 34599
Thanks Meter: 12
@infinitysupport..
see brot..not just me got this problem pls update lg main sw again.and i tested in lg mg100 too and same can't write to phone,but read ok.
@gumoff
if u want to make u phone life again try use versi lower than 1.27 .u phone can power up again but still can't solve problem.u phone dead because already erased..
good luck..br
Old 03-15-2008, 12:16   #10 (permalink)
gee4234's Avatar
Member: 86579
Thanks Meter: 70
mg295
hello infinity
i have a mg295 that i have tried to unlock selecting model mg296 LGA 1.27 and i have the same problem can read ok but cannot write i downgraded the to LGA version 1.26 and know it can write the problem is that i have flashed the phone with flash from support for version mg296.i made a flash backup before i tried to unlock it so its a working flash of mg295 please add this flash to support site and add model selection for mg295.also please fix bug in 1.27
Gee4234
Old 03-19-2008, 03:08   #11 (permalink)
Crazy Poster
Member: 491426
Thanks Meter: 3
kg290 dead by infinity .plz make the solution for flashing .. we are wating
Old 03-19-2008, 11:09   #12 (permalink)
Member: 130995
@hariskkj
Please, explain the problem more detailed
Old 03-22-2008, 15:41   #13 (permalink)
..:: i-MAX ::..'s Avatar
Member: 94762
Thanks Meter: 115
all time error
COM1 [Serial0] selected
Device: LG KG290
Action: flash write
Skip: Firmware (code)
Skip: File system
Skip: Alchemy data
Write: Eeprom
Boot...
Connecting, wait...
Boot Done
Set baud...
115200
Set baud Done
Check flash...
file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom__LG KG290_20080322-153753.B1E.bin
Check flash Done
Check space...
Check space Done
Check parameters...
Erase...
Erase Done
Write...
Write: Eeprom
Write Fail
Finished, time used: 44 sec
please correct this bug
Old 03-31-2008, 11:07   #14 (permalink)
rajtelecom's Avatar
Member: 446363
Sonork: 1577571:rajtelecom
Thanks Meter: 216
Device: LG KG290
Action: unlock
unlock method: enhanced
Boot...
Connecting, wait...
Boot Done
Set baud...
115200
Set baud Done
Check flash...
file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom__LG KG290_20080331-152707.B1E.bin
Check flash Done
Check space...
warning: Probably wrong model selected or unknown eeprom structure,
Are you sure you want to continue ?
Check space Done
Check parameters...
Erase...
Erase Done
Write...
write: lock area-1
error: can't write lock area
Write Fail
Finished, time used: 603 sec
Old 04-02-2008, 14:09   #15 (permalink)
Member: 417230
Thanks Meter: 2
OK there's a solution mate for your problem first use your HWK, update to the latest version 2.07 i think, but first install the latest support suite there's a method of installing the latest hwk version after everything is updated download the lg kg290 software, rebuild the imei in the hwk lg exe., im sure its already corrupt then flash the code data and alchemy data then unlock it again good luck mate.
LG - KG290 flashing error Dilip_Nath Infinity-Box 33 03-11-2011 18:57
LG KG290 after flash hange on starting LG KG290 logo ..::proudcracker::.. VygisToolbox 8 06-15-2009 20:53
<< LG KG290 still on logo>>help needed usman_ali FuriousGold 7 04-08-2009 21:15
unlock lg kg290 with multi-box stranger55 Multi-Box 5 07-05-2008 12:59
Lg KG290 unlock error Akili Bulent Infinity-Box 3 10-21-2007 19:31
Page generated in 0.24847 seconds with 9 queries
