07-16-2008, 23:34 | #1 (permalink) |
Junior Member Join Date: May 2004 Location: Poland, Stara Jabłonna Age: 43
Member: 66841 Status: Offline Thanks Meter: 0 | LG KG290 resets after flesh flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud... 460800 Set baud Done Check flash... current eeprom imei: 35745*********x file saved: C:\Program Files\InfinityBox\LGA\eeprom_3574*********x_LG-KG290_20080716-235653.B1E.bin .............. Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) flash: 89881600010001:89881600000000 Write: Alchemy data flash: 89881600010001:89881600000000 Write: Eeprom flash: 89881600000000:89881600000000 Write Done Finished, time used: 85049 sec Remove/Install battery now ! I flash phone to change the language after the surgery to reset and is still only a logo KG290. How can I fix this? I have a new version 1.31 LGA |
07-18-2008, 11:30 | #3 (permalink) |
Freak Poster Join Date: Jan 2006
Member: 224810 Status: Offline Thanks Meter: 15 | same problem i use these files KG290P40-07-V10b-***-XX_OCT-22-2007-CodeData_w_calibration[1].B1M.bin KG290P40-07-V10b-***-XX_OCT-22-2007_AlchemyData[1].B1P.bin i flashed with InfinityUpdate_LgA_v1[1].29.rar software |
07-18-2008, 12:05 | #5 (permalink) |
Member: 224810 Status: Offline Thanks Meter: 15 | i tried KG290P40-ARB-V10b-***-XX_SEP-10-2007_AlchemyData[1].B1P.bin KG290P40-ARB-V10b-***-XX_SEP-10-2007_CodeData[1].B1M.bin also and after full flash there is wrong pacage message |
07-18-2008, 13:01 | #6 (permalink) |
Member: 224810 Status: Offline Thanks Meter: 15 | Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Eeprom flash: 89881600010001:89881600000000 Write Done error: wrong answer: C5 Finished, time used: 29 sec Remove/Install battery now ! |
07-18-2008, 22:13 | #7 (permalink) | |
What is \"wrong pacage\" ? Where you can see it ? What is exact text from phone back label ? | |
07-19-2008, 09:00 | #8 (permalink) |
Member: 66841 Status: Offline Thanks Meter: 0 | i use these files KG290P40-07-V10b-***-XX_OCT-22-2007-CodeData_w_calibration.B1M KG290P40-07-V10b-***-XX_OCT-22-2007_AlchemyData.B1P and KG290P40-ARB-V10b-***-XX_SEP-10-2007_CodeData.B1M KG290P40-ARB-V10b-***-XX_SEP-10-2007_AlchemyData.B1P the phone is pink KG290 made in CHINA |
07-19-2008, 10:25 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @f164 It\'s not so good idea to talk about general problem due to it\'s not exist. It may be small bugs for one or two models and we always ready to fix bugx (if it\'s exist) but please, do not say about general problem etc. without real test report. I hope next time you will me bore careful with your words about \"general problem\". @plitom What is exact text from phone back label ? |
07-19-2008, 11:57 | #11 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: algeria BBA BELIMOUR Age: 46
Member: 184351 Status: Offline Thanks Meter: 263 | Quote:
kg275 kg 290 so this is the idea no more ps:sorry for my words | |
07-20-2008, 23:22 | #13 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @f164 Phones that you talk about has different hardware problems. What was the problems exactly ? @plitom if problem still exist you can try to use the next files: http://rapidshare.com/files/13121796...-2007.RAR.html http://rapidshare.com/files/13122036..._2007.zip.html Last edited by InfinitySupport; 07-20-2008 at 23:53. |
lg kg290 white screen after flash | BIJOU8420 | VygisToolbox | 2 | 01-13-2012 14:22 |
LG KG290 after flash hange on starting LG KG290 logo | ..::proudcracker::.. | VygisToolbox | 8 | 06-15-2009 20:53 |
LG KG290 dead after unlocking | gumoff | Infinity-Box | 6 | 03-18-2008 21:15 |
lg kg300 dead after flesh | dimitron | Infinity-Box | 10 | 03-21-2007 11:46 |
LG G3100 Dead after fleshing | mohangbvk | HWK | 1 | 02-01-2006 07:03 |
