04-07-2009, 11:32 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Android developers
Member: 904753 Status: Offline Sonork: 100.1583681 Thanks Meter: 2,677 | Lg kg290 unlock done module v1.38 Device: LG-KG290 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 35745601****** file saved: C:\Program Files\InfinityBox\LGA\eeprom_357456016******_LG-KG290_20090407-152943.B1E.bin .... Check flash Done Check space ... current eeprom imei: 357456016****** ......................................... finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 56 sec Remove/Install battery now ! Thanx INFINITY |
The Following User Says Thank You to ..::Waqar::.. For This Useful Post: |
04-07-2009, 19:26 | #2 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
LG kg290 - Unlock Code | shaz666 | LG Hardware Repair | 7 | 08-16-2008 09:36 |
what cable for lg kg290 unlock? | JOHN2003. | HWK | 3 | 06-04-2008 08:54 |
LG KG290 unlocked in infinity-box using standard method | amps_jas | Infinity-Box | 1 | 01-08-2008 13:56 |
Lg Kg290 Unlock Ok | PARMATMA | Multi-box LITE | 0 | 10-31-2007 07:52 |
Lg KG290 unlock error | Akili Bulent | Infinity-Box | 3 | 10-21-2007 19:31 |
