Old 10-21-2007, 14:53   #1 (permalink)
Member: 113924
Thanks Meter: 29
Lg KG290 unlock error
Why don't unlock my phone ?
COM5 [VCP128] selected
Device: LG KG290
Checking data, wait...
advanced flash detection active
Action: unlock
unlock method: standard
Boot...
Phone must be POWERED-OFF !
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: 89881600010001:89881600000000
flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb
Boot Done
Set baud...
921600
Set baud Done
Check flash...
current eeprom imei: 357456012620xxx
file saved: backup_eeprom_357456012620xxx_LG KG290_20071021-154441.B1E.bin
Check flash Done
Check space...
finalization done
Check space Done
Check parameters...
Check parameters Done
Erase...
Erase Done
Write...
write: lock area-1
Write Done
error: wrong answer[C1]
Finished, time used: 38 sec
Remove/Install battery now !
Old 10-21-2007, 15:19   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
pls, try to repeat unlock process.
if it will be problems pls send backup eeprom file and operation.log file to [email protected]
Old 10-21-2007, 19:22   #3 (permalink)
ahmertelecom's Avatar
Member: 210880
Sonork: 100.1577765
Thanks Meter: 151
same problem here i think software bugs i try many times
Old 10-21-2007, 19:31   #4 (permalink)
Member: 130995
try to use "unlock method: enhanced"
if no luck: http:///vbb/showpo...19&postcount=2
LG - KG290 flashing error Dilip_Nath Infinity-Box 33 03-11-2011 18:57
LG KG290 Flashing Error ARS.Rehman Infinity-Box 9 04-08-2009 13:34
what cable for lg kg290 unlock? JOHN2003. HWK 3 06-04-2008 08:54
LG KG290 unlocked in infinity-box using standard method amps_jas Infinity-Box 1 01-08-2008 13:56
Lg Kg290 Unlock Ok PARMATMA Multi-box LITE 0 10-31-2007 07:52
Page generated in 0.16560 seconds with 9 queries
