12-24-2008, 10:37 | #1 (permalink) |
No Life Poster Join Date: Sep 2007
Member: 582790 Status: Offline Thanks Meter: 378 | lg kg300 format ffs Fail COM14 [VCP0] selected Device: LG-KG300 Checking data, wait... Action: NAND reset read mode: 00 Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6227:8A02:8A01]... CPU: MT6227 chip: 0031:4CE0:3C69 high speed disabled boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.0208 loader: 3.748.0 NAND: Toshiba TC58DVM92A1FT 512+16 32 pages, 66Mb NAND id: 9876A5C0 page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 NOR: 0098:004900000000 [01000000] NAND: 0098:007600A500C0 [04200000] Initialize Done Set baud... 230400 Set baud Done Identification... detect device identification#1... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation error: can't detect ffs address Identification Fail Finished, time used: 70 sec Remove/Install battery now ! Infinity team help me |
The Following User Says Thank You to gsm-world For This Useful Post: |
12-24-2008, 18:54 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | How to fix "LG-KG300 freez/restart": 1. Run ChineseMiracle software 2. Select model "MT6228 NAND" 3. Make "format" by "whole flash chip" method |
The Following 4 Users Say Thank You to InfinitySupport For This Useful Post: |
06-02-2010, 05:46 | #4 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | fixed "LG-KG300 freez/restart Quote:
fixed "LG-KG300 freez/restart sucssfully by this method even i was getting this error...... logs By MModule COM3 [VCP0] selected module v2.58 Device: LG-KG300 Checking data, wait... Action: NAND reset read mode: 01 Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6227:8A02:8A01]... CPU: MT6227 chip: 0031:1FC1:E446 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.0208 loader: 3.748.0 NAND: Toshiba TC58DVM92A1FT 512+16 32 pages, 66Mb NAND id: 9876A5C0 page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 NOR: 0098:004900000000 [01000000] NAND: 0098:007600A500C0 [04200000] Initialize Done Set baud ... 921600 Set baud Done Identification ... detect device identification#1... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation error: can't detect ffs address Identification Fail Finished, time used: 46 sec Remove/Install battery now ! by ChineseMiracle software COM3 [VCP0] selected module v3.14 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: erase whole flash chip interface: BROM_DLL_v3.952.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6227:8A02:8A01 status: FF bbchip bl ver: FE NOR flash id[005D]: 0098:004900000000 [TOSHIBA] TV00578002DABD chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00010000 NAND flash id[0012]: 0098:007600A500C0 [TOSHIBA] TC58DVM92A1FT chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00047000 external RAM [HW_RAM_SRAM, CS1] size: 00800000 done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/04000000 ffs size: 64Mb detect sec ro... detect custom parameters... detect project-id... project-id: 7S7315IN00-001-R1A detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 04 sw version: ARIMA27_05C_PCB01_GPRS_MT6227_S01.7S7315IN00-001-R1A.BIN project-id: 7S7315IN00-001-R1A, 00000000 code offset: 00000000 rom info structure: 2nd [standard] generation TCL-ID is absent detect NAND info... number of areas/bytes to read: 1:00010000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: incorrect header: 16F48BC039DCC35B320C8E4025A4E2C3 warning: can not detect header nfi area detection finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done ==================== New firmware detected (v.3.14, database date: 28.05.2010): ARIMA27_05C_PCB01_GPRS_MT6227_S01.7S7315IN00-001-R1A.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== Format (HW_STORAGE_NAND)... 00000000-03FFFFFF... Disconnect... done Finished, time used: 41 sec Remove/Install battery now ! IMEI REPAIR Action: "repair imei" Model: Autodetect 6228-6239 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: 135790246811220 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei-1: 352834010674790 verification Ok Finished, time used: 13 sec Remove/Install battery now ! | |
The Following User Says Thank You to akashub For This Useful Post: |
06-02-2010, 10:30 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, ==================== New firmware detected (v.3.14, database date: 28.05.2010): ARIMA27_05C_PCB01_GPRS_MT6227_S01.7S7315IN00-001-R1A.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== Thank you ! |
06-03-2010, 07:27 | #6 (permalink) | |
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | Flash file KG300 Quote:
COM3 [VCP0] selected module v2.58 Device: LG-KG300 Checking data, wait... advanced flash detection enabled Action: read NOR flash Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6227:8A02:8A01]... CPU: MT6227 chip: 0031:1FC1:E446 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: ARIMA27_05C_PCB01_GPRS_MT6227_S01.7S7315IN00-001-R1A.BIN ver. sw 2: 7S7315IN00-001-R1A, 00000000 detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: flash[ARIMA27_05C_PCB01_GPRS_MT6227_S01.7S7315IN00-001-R1A.BIN]_part_1_of_1... file saved: C:\Documents and Settings\bittu\Desktop\flash[ARIMA27_05C_PCB01_GPRS_MT6227_S01.7S7315IN00-001-R1A.BIN]_part_1_of_1_20100603-114308.A3X.bin Finished, time used: 582 sec Remove/Install battery now ! 4shared.com - online file sharing and storage - download flash[ARIMA27_05C_PCB01_GPRS_MT6227_S01.7S7315IN00-001-R1A.BIN]_part_1_of_1_20100603-114308.A3X.bin | |
03-09-2011, 11:07 | #8 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Select LG KG-300 model in list, go to service page, fill required imei number and press "Write". Alternatively you can also use Chinese Miracle module to repair imei number. Wr. | |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
03-09-2011, 11:29 | #9 (permalink) | |
No Life Poster Join Date: Jan 2005 Age: 42
Member: 106391 Status: Offline Thanks Meter: 37 | Quote:
i go to service page or repair page or chine miracle module but not entry for reair imei i use Mmodule: v3.79 chine miracle: v3.26 sorry my eng very bad tkanks for helps | |
03-09-2011, 12:10 | #10 (permalink) | |
You can simply use "Repair Blocked" option on "Service" page in Chinese Miracle to repair imei. Wr. | |
03-09-2011, 22:15 | #13 (permalink) | |
How to restore imei button: 1. Run Infinity-Box DongleManager: c:\InfinityBox\DongleManager\DongleManager.exe 2. Press "Read dongle serial number (S/N)" button 3. Set "UK-Edition" option OFF (disabled) ! | |
03-10-2011, 11:23 | #15 (permalink) |
Member: 106391 Status: Offline Thanks Meter: 37 | well done thanks all This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 16Mb number of areas/bytes to read: 1:01000000 reading (HW_STORAGE_NOR)... file saved: C:\InfinityBox\MModule\LG-KG300_ARIMA27_05C_PCB01_GPRS_MT6227_S01.7S7312CF00-001-R1B__fullflash_20110308-164115.B0M.bin area size: 64Mb number of areas/bytes to read: 1:04000000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... file saved: C:\InfinityBox\MModule\LG-KG300__firmware_20110308-183116.B4M.bin |
Lg Kg300 Format with Pinfinity | alfox | Infinity-Box | 4 | 07-08-2009 08:26 |
E730 formate ffs fail | Cobbysyms | UST Pro II | 0 | 05-14-2009 10:05 |
E730 formate ffs fail | Cobbysyms | UST Pro II | 0 | 05-13-2009 17:51 |
lg kg300 ki ffs file chahiyee | starmobilkhw22 | Infinity-Box | 2 | 07-09-2008 14:46 |
plz add lg kg300 unlock and format ffs option in next update | rajabrotherscom | Infinity-Box | 1 | 05-08-2007 12:19 |
