12-07-2008, 03:40 | #1 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Pinas Age: 45
Member: 91411 Status: Offline Sonork: 100.1584444 Thanks Meter: 372 | Lg Kg300 Format with Pinfinity Code: ==== log opened: [12/6/2008 6:12:24 PM] ==== Application: C:\Program Files\InfinityBox\MModule\MModule.exe Loading data, wait... [Infinity Box] v2.44 S/N: 3834:0111 Wait... Device: LG-KG300 Done ==== log: [12/6/2008 6:13:00 PM] ==== COM6 [VCP1] selected module v2.44 Device: LG-KG300 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6227:8A02:8A01]... CPU: MT6227 chip: 0031:EC2E:0000 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: ARIMA27_05C_PCB01_GPRS_MT6227_S01.7S-7312-BFR8-4.BIN ver. sw 2: 7S-7312-BFR8-4, 00000000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: flash[ARIMA27_05C_PCB01_GPRS_MT6227_S01.7S-7312-BFR8-4.BIN]_part_1_of_1... file saved: C:\Program Files\InfinityBox\MModule\flash_lg_kg300[ARIMA27_05C_PCB01_GPRS_MT6227_S01.7S-7312-BFR8-4.BIN]_part_1_of_1_20081206-184158.A3X.bin Finished, time used: 1741 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [12/6/2008 6:42:47 PM] ==== COM6 [VCP1] selected module v2.44 Action: reset settings Model: LG-KG300 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6227:8A02:8A01]... CPU: MT6227 chip: 0031:EC2E:0000 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6227,E02 Date: 2005.04.12 Version: 1.0 Version: 7S-7312-BFR8-4 Version: EP1 60 byte(s) read imei: 35283401059771 connection Ok building list... done items to clear: 194 warning: wrong packet cs warning: wrong packet cs items cleared: 194 of 194 building list... done items remains: 0 Finished, time used: 43 sec Remove/Install battery now ! Action: imei Model: LG-KG300 Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6227, E02 Hardware version: EP1 Software version: 7S-7312-BFR8-4" Software date: 2005.04.12 Barcode: MT012345678901234567 imei: 135790246811220 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei: 352834010597710 verification Ok Finished, time used: 95 sec Power off phone now ! |
The Following User Says Thank You to alfox For This Useful Post: |
07-08-2009, 07:30 | #3 (permalink) |
No Life Poster Join Date: Nov 2007 Location: ☆I-LOVE Pakistan☆
Member: 627475 Status: Offline Sonork: 100.1594828 Thanks Meter: 1,144 | brother my lg kg 300 report COM9 [VCP0] selected module v2.75 Device: LG-KG300 Checking data, wait... Action: NAND reset read mode: 01 Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... error: boot phase#1 failed Release Power button now ! Boot Fail Finished, time used: 3 sec Remove/Install battery now ! |
07-08-2009, 08:21 | #4 (permalink) | |
If phone can not be detected by software it's for sure cable problem. Please, double check your cable and repeat process. | |
07-08-2009, 08:26 | #5 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | LG KG300 COMPLETE SOLUTION |
lg kg300 format ffs Fail | gsm-world | Infinity-Box | 15 | 03-13-2011 02:14 |
lg k200 format with help of pinfinder | joni_rajpura | Infinity-Box | 2 | 12-31-2008 17:42 |
Lg Kg300 Dead after format | adnanskyland | SpiderMan | 3 | 12-25-2008 06:30 |
lg kg300 restarting solved with format also pinfinding with pinfinder | joni_rajpura | Infinity-Box | 3 | 12-09-2008 14:01 |
plz add lg kg300 unlock and format ffs option in next update | rajabrotherscom | Infinity-Box | 1 | 05-08-2007 12:19 |
