LG KG300 restart The set is not getting boot by the box. I did with KG 200 cable (mini jack 4pin) and also with the motorola type pin(usb mini 5pin) but the set is not getting detected. the set is not water clogged or dropped. It is having restart problem it gets on and suddenly gets off. Need help InfinityTeam please. Thanks in advance. |
1 Attachment(s) Quote:
Only format ffs your problem will be solved how to make cable see here ...... |
I have the cable But the set is no getting attach to the box. The set i not getting boot. Here is the LOG "Action: reset settings Model: LG-KG300 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect error: boot phase#2/1 failed Can't initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. eeprom/ffs serious damaged, use repair eeprom/ffs files or use other unlock/format method error: operation failed ! Finished, time used: 7 sec Remove/Install battery now !" |
Also check that phone connector is soldered well and is not damaged |
Every thing is being properly checked but cannot Detect the set. |
Phone can not be booted only in this situation: 1. cable problem 2. wrong COM port selection 3. damaged phone hardware (f.e. connector or CPU or anything else) Please, select any of these reasons |
Thanks Infinity my problem solved By reason No 3. I replace the connector of the phone and then formated. |
