07-03-2008, 09:25 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Inside Boxes
Member: 228871 Status: Offline Thanks Meter: 43 | LG KG300 restart Thanks in advance. |
07-03-2008, 09:38 | #2 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: Space
Member: 352237 Status: Offline Sonork: 100.1577161 Thanks Meter: 605 | Quote:
Only format ffs your problem will be solved how to make cable see here ...... | |
07-03-2008, 09:46 | #3 (permalink) |
Member: 228871 Status: Offline Thanks Meter: 43 | I have the cable But the set is no getting attach to the box. The set i not getting boot. Here is the LOG "Action: reset settings Model: LG-KG300 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect error: boot phase#2/1 failed Can't initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. eeprom/ffs serious damaged, use repair eeprom/ffs files or use other unlock/format method error: operation failed ! Finished, time used: 7 sec Remove/Install battery now !" |
07-03-2008, 11:13 | #4 (permalink) | |
Also check that phone connector is soldered well and is not damaged | |
07-04-2008, 11:30 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Phone can not be booted only in this situation: 1. cable problem 2. wrong COM port selection 3. damaged phone hardware (f.e. connector or CPU or anything else) Please, select any of these reasons |
07-04-2008, 12:18 | #7 (permalink) | |
Member: 228871 Status: Offline Thanks Meter: 43 | Quote:
Thanks Infinity my problem solved By reason No 3. I replace the connector of the phone and then formated. | |
LG KG300 Restart Problem! | Was33m | LG | 13 | 12-13-2008 06:44 |
LG KG300 restart????? | Zerik4u | Infinity-Box | 12 | 10-29-2008 20:53 |
Lg Kg300 Restart | alfin5557 | Infinity-Box | 15 | 08-15-2008 13:06 |
LG kg300 restarting problem | sphameed | LG | 4 | 02-24-2008 16:50 |
LG KG300 Restart Problem | Miftahudin | Infinity-Box | 3 | 09-25-2007 18:51 |
