Old 09-05-2008, 05:54   #1 (permalink)
Crazy Poster
Member: 108937
Thanks Meter: 8
LG KG300 restart?????
COM6 [VCP0] selected
Action: reset settings
Model: LG-KG300
Checking data, wait...
19200 autodetect
Initializing[6227:8A02:8A01]...
CPU: MT6227
chip: 0031:006A:63E4
Connecting, wait...
error: can't finalize test mode
repeat operation and HOLD phone "Power" button long time !
error: operation failed !
Finished, time used: 100 sec
Remove/Install battery now !
Plz help.
Old 09-05-2008, 06:04   #2 (permalink)
nasirkhan007's Avatar
Member: 553445
Sonork: 100.1585581
Thanks Meter: 8,185
first chack speed than chack battery must be full charge
Old 09-05-2008, 07:11   #3 (permalink)
Deepakranasaria's Avatar
Member: 388207
Thanks Meter: 221
Check Cable Also Mate Many Time Due To Bad Connection This Problem Occurs
Old 09-05-2008, 11:59   #4 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,289
@Zerik4u
Double check cable.
Press and hold phone "power" button for long time during boot process
Old 09-05-2008, 12:29   #5 (permalink)
Crazy Poster
Member: 108937
Thanks Meter: 8
at this time i have 3 kg300 phones in my shop 2 phones with restarting problum and 1 phone is ok.
speed : chacked 115200 to 921600 chacked
battery : chacked 3 battery also voltage suply
Cable : chacked these cables
a.my working cable
b.new from shop
c.remaded cable
d.pinfinder L4A
i also flashed both phones but same
when i flash the phone {Format FFS during write (reset to default values) option unchacked phone is same
but
when i flash the phone with that option chacked phone go to daed
i also flash the readed flash file from working 3rd phone but
phone not flash with this file and give message (Data error)
this is log from last opration:
Device: LG-KG300
eeprom backup enabled, it may takes several minutes !
Action: read NOR flash
Boot...
19200 fixed
Connecting, wait...
CPU: MT6227
chip: 0031:5E41:2158
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 98004900000002:29EA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
Initialize Done
Set baud...
921600
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: ARIMA27_05C_PCB01_GPRS_MT6227_S01.7S7312SA00-001-R1C.BIN
ver. sw2: 7S7312SA00-001-R1C, 00000000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading: flash[ARIMA27_05C_PCB01_GPRS_MT6227_S01.7S7312SA00-001-R1C.BIN]_part_1_of_1...
file saved: E:\Program Files\InfinityBox\Flashes\LG\KG300\flash[ARIMA27_05C_PCB01_GPRS_MT6227_S01.7S7312SA00-001-R1C.BIN]_part_1_of_1_20080905-164929.A3X.bin
Finished, time used: 517 sec
Loading file v.02...
Loading failed, probably damaged data file.
detecting languages...
Languages: not detected
Old 09-05-2008, 12:35   #6 (permalink)
Crazy Poster
Member: 108937
Thanks Meter: 8
Originally Posted by InfinitySupport View Post
@Zerik4u
Double check cable.
when i Press and hold phone "power" button for long time during Format
phone keep restarting and atlast:
Finished, time used: 97 sec
Old 09-05-2008, 12:45   #7 (permalink)
Member: 130995
Hello,
Try to make this way:
1. run ChineseMiracle software
2. select model "MT6228 NAND"
3. make "format" by different methods
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 09-05-2008, 13:03   #8 (permalink)
Crazy Poster
Member: 108937
Thanks Meter: 8
Hello,
safe mode :
Model: Autodetect 6228, 6230 NAND
19200 autodetect
CPU: MT6227
high speed boot enabled
chip: 0031:FBC1:E6F6
Connecting, wait...
Finished, time used: 101 sec
complete mode:
Device: Autodetect 6228, 6230 NAND
Action: NAND reset
read mode: 01
Boot...
19200 fixed
Connecting, wait...
CPU: MT6227
Boot Done
Initialize...
version: 3.0208
loader: 3.748.0
NAND: Toshiba TC58DVM92A1FT 512+16 32 pages, 66Mb
NAND id: 9876A5C0
page size: 200+10
pages/block: 20
bits i/o: 08
address cycles: 04
blocks: 1000
NOR: 0098:004900000000 [01000000]
NAND: 0098:007600A500C0 [04200000]
Initialize Done
Set baud...
460800
Set baud Done
Identification...
reading structure area...
detecting structure...
warning: incorrect bootloader header: 098BFC47D1C264AA5F461BD73B856986
nfi area detection finished: failed
error: can't detect nand chip parameters, default values assigned
error: can't detect ffs address
Identification Fail
Finished, time used: 49 sec
whole flash chip (firmware + ffs):
Action: erase flash chip
Boot...
19200 fixed
Connecting, wait...
CPU: MT6227
Boot Done
Initialize...
version: 3.0208
loader: 3.748.0
NAND id: 9876A5C0
page size: 200+10
pages/block: 20
bits i/o: 08
address cycles: 04
blocks: 1000
Initialize Done
Set baud...
460800
Set baud Done
Identification...
Identification Done
Write...
formatting...
.................................................. .................................................. Write Done
Finished, time used: 57 sec
my phone is now ok
i will chack my 2nd phone
thank you so mach @InfinitySupport and all friends
The Following User Says Thank You to Zerik4u For This Useful Post:
Old 09-05-2008, 13:11   #9 (permalink)
Crazy Poster
Member: 108937
Thanks Meter: 8
this is 2nd phone log:
Boot...
19200 fixed
Connecting, wait...
CPU: MT6227
Boot Done
Initialize...
version: 3.0208
loader: 3.748.0
NAND id: 9876A5C0
page size: 200+10
pages/block: 20
bits i/o: 08
address cycles: 04
blocks: 1000
Initialize Done
Set baud...
460800
Set baud Done
Identification...
warning: incorrect bootloader header: 5305D03007178207D44A2536480C0800
Identification Done
Write...
formatting...
Finished, time used: 56 sec
both phones are ok.
The Following 2 Users Say Thank You to Zerik4u For This Useful Post:
Old 09-05-2008, 13:27   #10 (permalink)
Member: 130995
Thank you very much for test report !
Each test report with attached logs is very important for us so we can see how is Infinity-Box
software works and what is possible problems and successfully done work.
Old 10-29-2008, 17:05   #11 (permalink)
Registered User
Member: 473907
Thanks Meter: 63
sir i hv 3 sets but same problem plzzzz solve this one
Old 10-29-2008, 17:20   #12 (permalink)
Member: 130995
Hello,
What is same problem ?
Old 10-29-2008, 20:53   #13 (permalink)
yawarniazi's Avatar
Member: 194128
Thanks Meter: 303
Boot...
19200 fixed
Connecting, wait...
CPU: MT6227
Boot Done
Initialize...
version: 3.0208
loader: 3.748.0
NAND id: 9876A5C0
page size: 200+10
pages/block: 20
bits i/o: 08
address cycles: 04
blocks: 1000
Initialize Done
Set baud...
460800
Set baud Done
Identification...
Identification Done
Write...
formatting...
both phones are ok.
For you all who are facing problem in repairing KG300. Must make sure to follow the above flashing log. The Red text show the options to select manually for repairing KG300.
1- Device: Autodetect 6228, 6230 NAND
2- Action: erase flash chip
These options should be selected manually to repair this phone.
The full procedure is also available on Infinity Support Site under "manuals" folder. Just look at the document named "LG KG300 restart freeze repair.txt"
BEST OF LUCK
yawarniazi
The Following User Says Thank You to yawarniazi For This Useful Post:
LG KG300 Restart Problem! Was33m LG 13 12-13-2008 05:44
Lg Kg300 Restart alfin5557 Infinity-Box 15 08-15-2008 13:06
LG KG300 restart That'sme Infinity-Box 6 07-04-2008 12:18
LG kg300 restarting problem sphameed LG 4 02-24-2008 15:50
LG KG300 Restart Problem Miftahudin Infinity-Box 3 09-25-2007 18:51
Page generated in 0.43610 seconds with 8 queries
