01-12-2010, 18:43 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Location: BELARUS, Minsk Age: 44
Member: 59319 Status: Offline Sonork: 100.1606948 Thanks Meter: 82 | LG KM330 support I can read firmware from KM330 but can't connect it for IMEI repairing. I use the following pinout on the PCB Battery contact 1 2 3 4 tx gnd vbat rx SIM Code: ==== log: [12.01.2010 17:50:03] ==== COM6 [VCP2] selected module v3.01 Device: LG-KM330 Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.932.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! CPU: 6229:8A02:8A02 bbchip secure ver: FF bbchip bl ver: FE NOR flash chip: S_DA_NOR_FLASH_NOT_FOUND NAND flash chip: S_DONE flash id[0018]: 00AD:007900A50000 [HYNIX] HY27XA081G1M flash size: 128Mb page/spare size: 0200/0010 pages/block: 0020 bits i/o: 08 address cycles: 04 internal RAM: S_DONE size: 00020000 external RAM: S_DA_DEVICE_NOT_FOUND boot style: S_NAND_FLASH_BOOT bootcode current/expected: 3.2, 3.2 done Set baudrate (460800)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: KM330-00-V10i-CIS-XX-JUN-15-2009 detect NAND info... number of areas to read: 1 reading (HW_STORAGE_NAND)... nfi area detection... external bootloader is not present bootloader version: CIS_BOOTLOADER_V005_MT6229_KM330-00-V10I-CIS-XX-JUN-15-2009.bin nfi area detection finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 04 sw version: CIS_PCB03_GPRS_MT6229_S02.KM330-00-V10I-CIS-XX-JUN-15-2009.BIN project-id: KM330-00-V10i-CIS-XX-JUN-15-2009, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: 2nd [standard] generation TCL-ID is absent ===> done area size: 32Mb number of areas to read: 1 reading (HW_STORAGE_NAND)... file saved: D:\GSM\Infinity\Flash\KM330\LG-KM330_CIS_PCB03_GPRS_MT6229_S02.KM330-00-V10I-CIS-XX-JUN-15-2009__firmware_20100112-180730.B4X.bin Disconnect... done Finished, time used: 38 min 20 sec Remove/Install battery now ! ==== log opened: [12.01.2010 19:33:32] ==== Application: C:\Program Files\InfinityBox\MModule\MModule.exe Loading data, wait... [Infinity Box] MModule v3.02 S/N: 04F1:0112 Wait... Device: Aiko-17G Done COM6 ready Device: LG-KM330 Check your country laws before use this option ! In some countries this operation may be prohibited ! You must think serious before continue ! Do you understand above text well and want to continue ? Imei 357457---- already was repaired: 12.01.2010-17:48:52 Continue with this imei ? Action: "repair imei" Model: LG-KM330 Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! If you are sure that cable is good - select another baudrate (f.e. set baudrate to "autodetect") operation failed ! Finished, time used: 44 sec Remove/Install battery now ! Last edited by JC_BY; 01-12-2010 at 18:50. |
01-13-2010, 10:21 | #3 (permalink) | |
Member: 59319 Status: Offline Sonork: 100.1606948 Thanks Meter: 82 | Quote:
Code: ==== log opened: [12.01.2010 17:16:53] ==== Application: C:\Program Files\InfinityBox\MModule\MModule.exe Loading data, wait... [Infinity Box] MModule v3.01 S/N: 04F1:0112 Wait... Device: LG-KM330 Done COM6 ready Check your country laws before use this option ! In some countries this operation may be prohibited ! You must think serious before continue ! Do you understand above text well and want to continue ? Action: "repair imei" Model: LG-KM330 Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! If you are sure that cable is good - select another baudrate (f.e. set baudrate to "autodetect") operation failed ! Finished, time used: 46 sec Remove/Install battery now ! | |
01-13-2010, 16:16 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, try to repair imei with "method 2" witth this software: http://www.infinity-box.com/download...e_v3.07_v1.rar |
01-14-2010, 15:14 | #5 (permalink) | |
Code: ==== log: [14.01.2010 16:10:50] ==== COM6 selected module v3.07 Action: "repair imei" imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6229:8A02:8A02]... CPU: MT6229 high speed boot On chip: 0031:000D:0101 status: FF rom: 4D5710FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6229,E02 Date: 2005.07.11 Version: 1.0 Version: KM330-00-V10i-CIS-XX-JUN-15-2009 Version: EP1 detecting structure #2... 0warning: wrong packet cs done 44 byte(s) read imei: connection Ok detecting structure #2... warning: wrong packet cs 0 done 44 byte(s) read verification... verification done: Finished, time used: 23 sec Remove/Install battery now ! | |
The Following User Says Thank You to JC_BY For This Useful Post: |
lg brand supported in hwk support area not found in lg software | bkhatti | HWK | 4 | 12-21-2008 17:49 |
NEW - LG KP135 SUPPORTED - LG Workshop v1.90SC is uploaded at support sites | Gobi | VygisToolbox | 18 | 07-03-2008 15:14 |
LG 500 and LG A7110 support? | vhanda | Blazer | 1 | 01-27-2006 11:06 |
@Mr.Vygis: pls upgrade LG-software for LG-G1800 support | anhtam | VygisToolbox | 0 | 12-28-2005 13:11 |
@ julvir please add LG W7000 and LG 7030 SUPPORT | MindPower | Redbox | 1 | 07-08-2004 21:19 |
