Old 12-24-2008, 03:26   #1 (permalink)
Member: 463037
Thanks Meter: 135
my220x keypad not work done by infinity
i wanna share my experience w/ sagem my220x all keypad not work.
just write new eerom from the support...100% the phone is working...
COM10 [VCP0] selected
Device: Sagem-my220x
Checking data, wait...
Action: flash write
Boot...
Press and HOLD Power button now (if boot does not start remove/install batery) !
loading...
middle part...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud...
115200
Set Baud Done
Connecting...
flash: 0001:011A
Connecting Done
Check hardware...
Check hardware Done
Check parameters...
Check parameters Done
backup critical area...
reading [eeprom-sta]...
file saved: C:\Program Files\InfinityBox\Pana01\my 220x\Sagem-my220x_eeprom-sta_20081224-100504.B1E.bin
loading data...
data loaded
reading [eeprom-sec]...
file saved: C:\Program Files\InfinityBox\Pana01\my 220x\Sagem-my220x_eeprom-sec_20081224-100518.B1E.bin
reading [eeprom-complete]...
file saved: C:\Program Files\InfinityBox\Pana01\my 220x\Sagem-my220x_eeprom-complete_20081224-100529.B1E.bin
backup critical area Done
Check memory...
Check memory Done
Write...
reset...
done
Erasing: Eeprom
Writing: Eeprom
Write Done
Finished, Remove/Install battery now !
Time used: 54 sec
The Following 2 Users Say Thank You to wilnert For This Useful Post:
Old 12-24-2008, 05:32   #2 (permalink)
madho's Avatar
Member: 647592
Thanks Meter: 191
thanks for a good inforamation
Old 12-24-2008, 05:53   #3 (permalink)
Member: 229636
Thanks Meter: 48
nice info sir and big refference to all.........
Old 12-24-2008, 19:35   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
Action: flash write
Boot...
loading...
middle part...
next part...
boot answer: 01
Boot Done
Set Baud...
115200
Set Baud Done
Connecting...
flash: 0001:011A
Connecting Done
Check hardware...
Check hardware Done
Check parameters...
loading data...
data loaded
Check memory...
Check memory Done
Write...
reset...
done
Erasing: Eeprom
Writing: Eeprom
Write Done
Time used: 54 sec
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works and what is
possible problems (so we will be able to fix it) and successfully done work.
kg195 auto off auto keypad buton working, keypad not working .by guljee guljee786 LG Hardware Repair 4 01-23-2011 18:41
6500s keypad not working done by via jumper mark_07 Nokia Base Band 5 ( BB-5 ) 11 03-17-2010 10:56
k310i keypad not working and joy stick not working how can i make jumper shani72 Sony Ericsson Hardware Repair 1 12-09-2009 16:58
2600c keypad not work up key,downkey,optionskey,cencelkey not work after change ic. lavkey Nokia Hardware & Hardware Repair 1 08-08-2008 16:52
V6 unlock done keypad not working chris2007 Smart-Clip 5 07-12-2008 08:36
Page generated in 0.22638 seconds with 9 queries
