Old 12-24-2008, 08:03   #1 (permalink)
mdoscorpio's Avatar
Member: 310068
Thanks Meter: 71
LG KP100 36secs. Unlocked
COM6 [VCP2] selected
Device: LG-KP100
Checking data, wait...
Action: unlock
direct unlock method #2 (Airtel etc.)
Boot...
Press and HOLD Power button now (if boot does not start remove/install batery) !
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud...
115200
Set Baud Done
Connecting...
flash: 0001:011A
Connecting Done
Check hardware...
sw version: ULC2GL 2008-03-06 1.0 TMO_UK KP100 01 FL 44 V10a 234-30 MAR-0
Check hardware Done
Check parameters...
Check parameters Done
backup critical area...
reading [eeprom-sta]...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sta_20081224-145824.B1E.bin
loading data...
data loaded
imei: 35847902106358500
reading [eeprom-sec_35847902106358500]...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sec_35847902106358500_20081224-145829.B1E.bin
reading [eeprom-complete_35847902106358500]...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35847902106358500_20081224-145837.B1E.bin
backup critical area Done
Check memory...
Check memory Done
Write...
Erasing: eeprom-sec
Writing: eeprom-sec
probably you need to restore original imei after unlock process
Write Done
Finished, Remove/Install battery now !
Time used: 36 sec
The Following User Says Thank You to mdoscorpio For This Useful Post:
Old 12-24-2008, 08:33   #2 (permalink)
Umair Rashid's Avatar
Member: 421117
Sonork: +92 346 5544377 (PHONE)
Thanks Meter: 2,522
well done !!
Old 12-24-2008, 19:32   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Device: LG-KP100
Action: unlock
Boot...
loading...
next part...
boot answer: 01
Boot Done
Set Baud...
115200
Set Baud Done
Connecting...
flash: 0001:011A
Connecting Done
Check hardware...
Check hardware Done
Check parameters...
loading data...
data loaded
Check memory...
Check memory Done
Write...
Erasing: eeprom-sec
Writing: eeprom-sec
Write Done
Time used: 36 sec
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works and what is
possible problems (so we will be able to fix it) and successfully done work.
LG KP100 Successfully Unlocked zeerik Infinity-Box 11 06-18-2012 08:24
LG KP100 after unlock wrong imei Blade_hun HWK 8 09-03-2009 05:49
lg kp100 not unlock Imrankhan Infinity-Box 3 04-05-2009 06:36
vodafone 125 & LG KP100 success unlock by infinity raffy_84 Infinity-Box 5 10-20-2008 15:17
LG KP100 Ruby Unlock? Sharpharp HWK 9 08-08-2008 13:12
Page generated in 0.26785 seconds with 9 queries
