11-14-2011, 06:58 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Lg kp100 blink not solved |
11-17-2011, 07:10 | #3 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | thanks sir i will solv now here log ==== [11/16/2011 11:46:19 PM] ==== COM3 [VCP0] selected module v1.78 Device: LG-KP100 Checking data, wait... Action: "sp-unlock" direct unlock method #2 (Airtel etc.) Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: .01 ULC2GL KP105 KP100 P16 00 AFR V10c AFR-XX JAN-03-2008 Check parameters Done backup critical area ... reading eeprom-static... file saved: c:\InfinityBox\Pana01\LG-KP100_eeprom-static_20111116-234638.B1E.bin loading data... data loaded imei: 35*********** reading eeprom-security_35********.. file saved: c:\InfinityBox\Pana01\LG-KP100_eeprom-security_35*******_20111116-234639.B1E.bin reading eeprom-complete_35*******.. file saved: c:\InfinityBox\Pana01\LG-KP100_eeprom-complete_35********_20111116-234645.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-security Writing: eeprom-security probably you need to restore original imei after unlock process Write Done Finished, time used: 25 sec Remove/Install battery now ! |
The Following User Says Thank You to Deepesh Sharma For This Useful Post: |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
hope it is not too comercial | aleksj | Wanted Products | 0 | 06-12-2000 13:22 |
Nokia 5110 - "SIMcard not accepted". | Kond | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-02-2000 22:46 |
winlock wintesla m2bus do not work | Bigbrothers2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-26-2000 14:31 |
