02-28-2009, 17:38 | #1 (permalink) |
Freak Poster Join Date: Dec 2004 Location: UNITED KINGDOM
Member: 96918 Status: Offline Sonork: 100.1602725 Thanks Meter: 32 | lg kp100 blinking |
02-28-2009, 18:55 | #2 (permalink) | |
Did you tried to make "sp-unlock" operation ? | |
03-01-2009, 08:52 | #6 (permalink) |
Member: 96918 Status: Offline Sonork: 100.1602725 Thanks Meter: 32 | sir i recive mobile in working condison from costmer.he just said me change the o2 software i change it software succesfully flash.then i have problam lg blinking. then i try to use with o2 flash file but not alive |
03-01-2009, 09:00 | #8 (permalink) |
Member: 96918 Status: Offline Sonork: 100.1602725 Thanks Meter: 32 | i try many times, resetting but not done . i know its not hardware problam maybe my flash proceger is not right.tell me step by step how flash perfect kp100 |
03-01-2009, 09:08 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | use firmware + lp files flash phone with firmware + lp flash phone with any repair eeprom make sp-unlock How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software |
Lg kp100 blinking problem | ali_imran | ET-BoX | 2 | 03-02-2009 09:53 |
Lg Kp100 | DUSKnenixs | Multi-Box | 8 | 09-12-2008 22:10 |
30 Apr 2008: LG KP100 model supported, Sagem, Vodafone unlock improved | InfinitySupport | Infinity-Box | 51 | 05-07-2008 20:25 |
30/04/2008 LG KP100,KP105,KP105A,KP105B,KP106 Code Reader Added | samigsm78 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 9 | 05-05-2008 11:22 |
LG KP100 not supported but it can be | fethi | Infinity-Box | 1 | 04-27-2008 21:03 |
