04-04-2009, 11:47 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: world
Member: 573962 Status: Offline Sonork: 100.1603021 Thanks Meter: 480 | lg kp100 not unlock i unlock all methood and imei change and reset too but not unlocked COM1 [VCP0] selected module v1.60 Device: LG-KP100 Checking data, wait... Action: unlock direct unlock method #1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .01 ULC2GL RELIANCE KP100 01 FL 91 V10d 404-83 SEP-30-2008 +0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20090404-160917.B1E.bin loading data... data loaded imei: 35588202400937700 reading eeprom-security_35588202400937700... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35588202400937700_20090404-160918.B1E.bin reading eeprom-complete_35588202400937700... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35588202400937700_20090404-160924.B1E.bin backup critical area Done Check memory ... loading data... error: source buffer too small: 00000011 instead of 000001DA error: operation terminated [00FF] loading data... error: source buffer too small: 00000011 instead of 000001DA error: operation terminated [00FF] loading data... error: source buffer too small: 00000011 instead of 000001DA error: operation terminated [00FF] loading data... data loaded code: 22424936 error: not locked or unknown eeprom Check memory Failed Finished, time used: 25 sec Remove/Install battery now ! COM1 [VCP0] selected module v1.60 Device: LG-KP100 Checking data, wait... Action: unlock read unlock codes Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .01 ULC2GL RELIANCE KP100 01 FL 91 V10d 404-83 SEP-30-2008 +0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20090404-161010.B1E.bin loading data... data loaded imei: 35588202400937700 reading eeprom-security_35588202400937700... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35588202400937700_20090404-161011.B1E.bin reading eeprom-complete_35588202400937700... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35588202400937700_20090404-161017.B1E.bin backup critical area Done Check memory ... loading data... data loaded code: 22424936 Finished, time used: 20 sec Remove/Install battery now ! COM1 [VCP0] selected module v1.60 Device: LG-KP100 Checking data, wait... Action: reset Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .01 ULC2GL RELIANCE KP100 01 FL 91 V10d 404-83 SEP-30-2008 +0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20090404-161157.B1E.bin loading data... data loaded imei: 35586201000000200 reading eeprom-security_35586201000000200... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35586201000000200_20090404-161158.B1E.bin reading eeprom-complete_35586201000000200... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35586201000000200_20090404-161204.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Write Done Finished, time used: 24 sec Remove/Install battery now ! |
04-04-2009, 15:17 | #2 (permalink) |
No Life Poster Join Date: Oct 2007 Location: india
Member: 618404 Status: Offline Thanks Meter: 311 | How to unlock LG KP100: 1. Make "read unlock codes" 2. Power-On phone with accepted SIM card 3. Type: 2945#*20001# 4. MENU -> SETTINGS (5) -> SECURITY (7) -> (6) -> (1) -> OK -> enter unlock code wbr. rajesh ch. |
04-04-2009, 15:46 | #3 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
http://forum.gsmhosting.com/vbb/show...1&postcount=16 | |
The Following User Says Thank You to deepakgarg For This Useful Post: |
lg bl20 not unlocking | simlock | Z3X-Team Products | 1 | 03-29-2010 18:47 |
lg kp100 not boot | soy | Infinity-Box | 13 | 10-31-2008 12:29 |
vodafone 125 & LG KP100 success unlock by infinity | raffy_84 | Infinity-Box | 5 | 10-20-2008 15:17 |
LG KP100 Ruby Unlock? | Sharpharp | HWK | 9 | 08-08-2008 13:12 |
LG KP100 not supported but it can be | fethi | Infinity-Box | 1 | 04-27-2008 21:03 |
