06-29-2009, 07:19 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: syria
Member: 205475 Status: Offline Thanks Meter: 179 | lg kp100 successfully flashed to arabic the phone did not gave any network . so i flashed it by pack up epprom the phone now return lock so i flashed it by newest flash file from support and unlock (virtel) then flash it by arabic flash file the phone now ok thanx infinity team |
06-29-2009, 09:38 | #3 (permalink) |
Member: 205475 Status: Offline Thanks Meter: 179 | ==== log opened: [28/06/2009 12:52:16 م] ==== Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.68 S/N: 356E:0112 Wait... Device: LG-KP100 Ready COM7 ready Loading file v.04... KP100-TMO-CZ-00-420-V10a_230-01_MAR-06-2008+0_En_Ru_De_Cz_Sk_firmware_lp.B1M.bin loaded ==== log: [28/06/2009 12:52:52 م] ==== COM7 [VCP1] selected module v1.68 Device: LG-KP100 Checking data, wait... Action: flash write error: no data for Language Pack ==== log: [28/06/2009 12:53:14 م] ==== COM7 [VCP1] selected module v1.68 Device: LG-KP100 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .01 ULC2GL KP105 KP100 P16 00 ARB V10b ARB-XX DEC-27-2007 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20090628-125331.B1E.bin loading data... data loaded imei: 35996101237367600 reading eeprom-security_35996101237367600... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35996101237367600_20090628-125332.B1E.bin reading eeprom-complete_35996101237367600... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35996101237367600_20090628-125333.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware Writing: Firmware Erasing: Firmware Writing: Firmware Write Done Finished, time used: 121 sec Remove/Install battery now ! ==== log: [28/06/2009 12:56:20 م] ==== COM7 [VCP1] selected module v1.68 Device: LG-KP100 Checking data, wait... Action: unlock read unlock codes Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .01 ULC2GL 2008-03-06 1.0 TMO_CZ KP100 00 420 V10a 230-01 MA Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20090628-125633.B1E.bin loading data... data loaded imei: 35996101237367600 reading eeprom-security_35996101237367600... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35996101237367600_20090628-125634.B1E.bin reading eeprom-complete_35996101237367600... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35996101237367600_20090628-125635.B1E.bin backup critical area Done Check memory ... loading data... data loaded code: 51563353 Finished, time used: 12 sec Remove/Install battery now ! ==== log: [28/06/2009 01:02:31 م] ==== COM7 [VCP1] selected module v1.68 Device: LG-KP100 Checking data, wait... Action: read eeprom Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .01 ULC2GL 2008-03-06 1.0 TMO_CZ KP100 00 420 V10a 230-01 MA Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20090628-130244.B1E.bin loading data... data loaded imei: 35996101237367600 reading eeprom-security_35996101237367600... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35996101237367600_20090628-130244.B1E.bin reading eeprom-complete_35996101237367600... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35996101237367600_20090628-130246.B1E.bin backup critical area Done Check memory ... completed Finished, time used: 11 sec Remove/Install battery now ! Loading file v.02... KP105_KP100_P16-00_ARB_V10b_ARB-XX_DEC-27-2007+0_firmware_lp.B1M.bin loaded ==== log: [28/06/2009 01:03:25 م] ==== COM7 [VCP1] selected module v1.68 Device: LG-KP100 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .01 ULC2GL 2008-03-06 1.0 TMO_CZ KP100 00 420 V10a 230-01 MA Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20090628-130343.B1E.bin loading data... data loaded imei: 35996101237367600 reading eeprom-security_35996101237367600... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35996101237367600_20090628-130343.B1E.bin reading eeprom-complete_35996101237367600... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35996101237367600_20090628-130345.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware Writing: Firmware Erasing: Firmware Writing: Firmware Write Done Finished, time used: 122 sec Remove/Install battery now ! |
The Following User Says Thank You to anasshe For This Useful Post: |
LG KP100 Successfully Unlocked | zeerik | Infinity-Box | 11 | 06-18-2012 08:24 |
LG KP100 need flash file with bulgarian language | djems | LG | 0 | 02-23-2010 14:14 |
To look for,lg kp100 full flash | teslakemal | Infinity-Box | 1 | 04-11-2009 21:21 |
need lg kp100 russian flash file | tigran80 | Infinity-Box | 1 | 11-27-2008 19:35 |
vodafone 125 & LG KP100 success unlock by infinity | raffy_84 | Infinity-Box | 5 | 10-20-2008 15:17 |
