06-19-2008, 14:42 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | LG KP100 Ulocked Succeccfully LG KP100 Ulocked Succeccfully.........thanks infinity team here is log COM13 [VCP0] selected Device: LG-KP100 Checking data, wait... Action: unlock read unlock codes Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: ULC2GL O2 KP100 04 FL 49 V10a 262-07 FEB-12-2008 +2 ^ Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sta_20080619-235328.B1E.bin loading data... data loaded imei: 35996101263981100 reading [eeprom-sec_35996101263981100]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sec_35996101263981100_20080619-235336.B1E.bin reading [eeprom-complete_35996101263981100]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35996101263981100_20080619-235339.B1E.bin backup critical area Done Check memory... loading data... data loaded code: 44868611 Finished, Remove/Install battery now ! Time used: 39 sec now inter this code (44868611) acording to these info (How to unlock LG KP100: 1. make "read unlock codes" 2. power-on phone with accepted SIM card 3. type: 2945#*20001# 4. MENU -> SETTINGS (5) -> SECURITY (7) -> (6) -> (1) -> OK -> enter unlock code Enjoy |
The Following 12 Users Say Thank You to zeerik For This Useful Post: |
06-19-2008, 17:44 | #2 (permalink) |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
The Following User Says Thank You to InfinityN For This Useful Post: |
06-30-2008, 22:18 | #4 (permalink) |
Freak Poster Join Date: Nov 2003 Location: at work Age: 43
Member: 44690 Status: Offline Thanks Meter: 22 | all ok.unlocked. here log: COM18 [VCP0] selected Device: LG KP100 Checking data, wait... Action: unlock read unlock codes Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... flash chip supported sw version: ULC2GL O2 KP100 04 FL 49 V10a 262-07 FEB-12-2008 +2 ^ Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_LG KP100_eeprom-sta_20080701-000939.B1E.bin loading data... data loaded imei: 35996101747542700 reading [eeprom-sec_35996101747542700]... file saved: C:\Program Files\InfinityBox\Pana01\backup_LG KP100_eeprom-sec_35996101747542700_20080701-000943.B1E.bin reading [eeprom-complete_35996101747542700]... file saved: C:\Program Files\InfinityBox\Pana01\backup_LG KP100_eeprom-complete_35996101747542700_20080701-000951.B1E.bin backup critical area Done Check memory... loading data... data loaded code: 22102631 Finished, Remove/Install battery now ! Time used: 29 sec |
The Following 2 Users Say Thank You to ionutGSM For This Useful Post: |
07-18-2008, 07:25 | #7 (permalink) |
Registered User Join Date: May 2005 Location: My Office
Member: 143939 Status: Offline Thanks Meter: 264 | thanks infinityhelp in shell.exe Cable name: LG-KG800 keyboard top 1.........18 12: phone Rx (RJ45 pin-2) 13: phone Tx (RJ45 pin-3) 18: Gnd but not worked |
08-18-2008, 11:40 | #15 (permalink) |
No Life Poster Join Date: Jan 2005 Location: United Kingdom
Member: 109729 Status: Offline Thanks Meter: 36 | just for test... COM2 [VCP0] selected Device: LG-KP100 Checking data, wait... Action: unlock read unlock codes Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 460800 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: ULC2GL SUNRISE KP100 01 FL *** V10a 228-02 APR-14-2008 +0 ^ Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sta_20080818-132944.B1E.bin loading data... data loaded imei: 35996101734952300 reading [eeprom-sec_35996101734952300]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sec_35996101734952300_20080818-132949.B1E.bin reading [eeprom-complete_35996101734952300]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35996101734952300_20080818-133000.B1E.bin backup critical area Done Check memory... loading data... data loaded code: 70379283 Finished, Remove/Install battery now ! Time used: 53 sec used ordinary kg800 cable wbr tehgsm |
lg u8120 ulock by vygistoolbox | malangjlmi | VygisToolbox | 6 | 07-30-2011 14:31 |
LG GB220 Ulock code or software? | kazman300 | Phone Unlocking Codes & Maps | 0 | 12-01-2009 01:00 |
LG U8150 ulock problem | arabie | LG | 2 | 07-30-2008 07:01 |
LG KP100 Ulocked Succeccfully with TestCard | IkaMazini | Infinity-Box | 3 | 07-27-2008 10:20 |
LG KP100 not supported but it can be | fethi | Infinity-Box | 1 | 04-27-2008 21:03 |
