Old 12-22-2008, 12:39   #1 (permalink)
Member: 563167
Thanks Meter: 39
LG KP100 Unlocked okkk..
COM6 [VCP0] selected
module v1.57
Device: LG-KP100
Checking data, wait...
Action: unlock
direct unlock method #2 (Airtel etc.)
Boot ...
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
sw version: .01 ULC2GL O2 KP100 04 FL 49 V10a 262-07 FEB-12-2008 +2 ^
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20081222-112809.B1E.bin
loading data...
data loaded
imei: 35588202876423300
reading eeprom-security_35588202876423300...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35588202876423300_20081222-112811.B1E.bin
reading eeprom-complete_35588202876423300...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35588202876423300_20081222-112817.B1E.bin
backup critical area Done
Check memory ...
Check memory Done
Write ...
Erasing: eeprom-security
Writing: eeprom-security
probably you need to restore original imei after unlock process
Write Done
Finished, time used: 30 sec
Remove/Install battery now !
thanksssssssss to infinity team...........
The Following User Says Thank You to cllins For This Useful Post:
Old 12-22-2008, 12:53   #2 (permalink)
rana_'s Avatar
Member: 597570
Sonork: 100.1590733
Thanks Meter: 159
module v1.57
Device: LG-KP100
Action: unlock
Boot ...
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
loading data...
data loaded
Check memory ...
Check memory Done
Write ...
Write Done
it's very old history hehehe.....................
Old 12-22-2008, 18:24   #3 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,375
module v1.57
Device: LG-KP100
Action: unlock
Boot ...
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
loading data...
data loaded
Check memory ...
Check memory Done
Write ...
Write Done
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works and what is
possible problems (so we will be able to fix it) and successfully done work.
LG KP100 Unlock h4mza LG 8 07-03-2011 02:51
Lg KP100 unlocked sucessfull by n-box randr LG 0 09-13-2008 10:59
lg kp100 unlock newerno Infinity-Box 10 09-12-2008 10:26
LG KP100 unlock problem msashami Infinity-Box 1 09-02-2008 13:04
LG KP100 Unlock OK Amir-SkillZ Infinity-Box 0 08-12-2008 09:21
Page generated in 0.26153 seconds with 8 queries
