Old 02-12-2009, 10:56   #1 (permalink)
Vijendra Saini's Avatar
Member: 398557
Sonork: 100.1578489
Thanks Meter: 1,514
Lg kp100 were not unlocked
LG KP100 WERE NOT UNLOCKED
COM5 [VCP0] selected
module v1.62
Device: LG-KP100
Checking data, wait...
Action: unlock
direct unlock method #1
Boot ...
loader: standard
type: 4
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
460800
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
sw version: .01 ULC2GL RELIANCE KP100 01 FL 91 V10d 404-83 SEP-30-2008 +0
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20090212-152116.B1E.bin
loading data...
data loaded
imei: 35588202440771200
reading eeprom-security_35588202440771200...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35588202440771200_20090212-152117.B1E.bin
reading eeprom-complete_35588202440771200...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35588202440771200_20090212-152119.B1E.bin
backup critical area Done
Check memory ...
loading data...
error: source buffer too small: 00000011 instead of 000001DA
error: operation terminated [00FF]
loading data...
loading data...
loading data...
data loaded
code: 16743544
error: not locked or unknown eeprom
Check memory Failed
Finished, time used: 12 sec
Remove/Install battery now !
Ifinity team please tell me whats a error ?????
Old 02-12-2009, 11:19   #2 (permalink)
Member: 765452
Thanks Meter: 25
Here is mine also
module v1.62
Device: LG-KP100
Action: unlock
read unlock codes
Boot ...
loader: standard
type: 4
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20090212-154817.B1E.bin
loading data...
data loaded
imei: 35588202440876900
reading eeprom-security_35588202440876900...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35588202440876900_20090212-154817.B1E.bin
reading eeprom-complete_35588202440876900...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35588202440876900_20090212-154819.B1E.bin
Check memory ...
loading data...
data loaded
code: 77723319
Finished, time used: 11 sec
Old 02-12-2009, 11:27   #3 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,897
BRO U CAN CHECK THIS LINK I HAVE SUCESSFULLY UNLOCKED THIS VERSION OF KP100
THANKS INFINITY TEAM FOR THE FAST FESPONCE FOR THIS PHONE
Not able to unlock lg kp100 locked to reliance(smart gsm services) india
WBR
sahil2000ind
The Following 3 Users Say Thank You to sahil2000ind For This Useful Post:
Old 02-13-2009, 08:44   #4 (permalink)
Member: 398557
Sonork: 100.1578489
Thanks Meter: 1,514
WBR
sahil2000ind
Ok friend ill post a result here .
Old 02-13-2009, 09:07   #5 (permalink)
Member: 852575
Thanks Meter: 11
please do use pana1.61 or 1.62(aguale). download firmware from support and flash. its now unlocked .....enjoy. infinity team has told before that there is some bug in new pana 1.62. no problem always there is solution you work hard and try and try. i hope infinity will remove this bug very soon.
Old 02-13-2009, 17:22   #6 (permalink)
Member: 765452
Thanks Meter: 25
I had tried both of them [pana1.61 or 1.62(aguale)] but result were same.when we on handset after unlock it says invalid battery.plz help
Old 02-13-2009, 17:46   #7 (permalink)
Member: 765452
Thanks Meter: 25
Yes unlock sucessfull by sahil2000ind method
COM5 [VCP1] selected
module v1.61
Device: LG-KP100
Action: unlock
read unlock codes
Boot ...
loader: standard
type: 4
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
230400
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
sw version: .01 ULC2GL 2008-03-06 1.0 TMO_CZ KP100 00 420 V10a 230-01 MA
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20090213-221118.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35588202440771200_20090213-221119.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35588202440771200_20090213-221122.B1E.bin
Check memory ...
loading data...
data loaded
code: 16743544
Finished, time used: 15 sec
Thanks to sahil2000ind your method works.Unlock sucessful..............
The Following User Says Thank You to khanrizwan For This Useful Post:
Old 02-13-2009, 21:57   #8 (permalink)
AY29!4LYF's Avatar
Member: 914747
Thanks Meter: 22
infinity box always reading code on this model look @ d end there is a unlocking code in 8 digit put an non accepted sim card nd press unlock nd put your code read by infinity box keep it up thanks i done more then 150 pcs never error in any single 1 if u unlock an unlocked fone then it gives error error reading data r fone is not locked
i got backup of all of them
br
Old 02-14-2009, 08:26   #9 (permalink)
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,897
@AY29!4LYF
RELIANCE (smart mbile services india) HAS CHANGED THEIR SECURITY VERSION
sw version: .01 ULC2GL RELIANCE KP100 01 FL 91 V10d 404-83 SEP-30-2008 +0 THIS VERSION PROBABLY IS STILL NOT POSSIBLE TO UNLOCK BY DIRECT UNLOCK METHOD SO WE HAVE TO FLASH IT WITH OTHER FIRMWARE
I HAVE TESTED IT ON MORE THAT 200 MOBILES SETS WITHOUT ANY PROBLEM
@Infinitysupport
WE ALL MEMBERS ALSO WAITING FOR THE DIRECT UNLOCK METHOD FOR THIS VERSION AS IT TOO TIME TAKING TO FLASH ALL THE SETS TO UNLOCK
WBR
sahil2000ind
The Following User Says Thank You to sahil2000ind For This Useful Post:
Old 10-27-2009, 09:24   #10 (permalink)
sonitex's Avatar
Member: 229056
Thanks Meter: 95
module v1.70
Device: LG-KP100
Action: unlock
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
slowest
Set Baud Done
Connecting ...
Connecting Failed
Finished, time used: 7 sec
pleas help me i sett all baud rat
Old 10-27-2009, 10:32   #11 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,397
@sonitex
Try to press and hold phone "Power" button more long time.
Lg kp100 problem with unlock [Closed] iliya _angelov Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 16 05-07-2012 13:05
Lg KP100 reliance gsm unlock successfull abhishek aga ET-BoX 15 10-02-2011 18:23
LG Kp100...can not enter unlock code? :::SOLVED::: husainm PolarBox 3 2 02-19-2009 22:41
lg kp100 orange spain unlock problem SOLVED sunnagar PolarBox 3 2 09-20-2008 20:42
LG Kp100 fail to unlock. rotelcam Infinity-Box 3 08-17-2008 16:50
Page generated in 0.42593 seconds with 8 queries
