Old 05-26-2009, 16:02   #1 (permalink)
ehsas_ghum's Avatar
Member: 171512
Thanks Meter: 1,034
Thumbs up ;;;lg kp105 blinking problem;;;plz answer;;;
LG KP105 BLINKING PROBLEM WHEN I TRY TO FLASH WITH KP105 FIRMWEAR SET GIVE WRIGHTING ERROR BUT WHEN FLASH WITH KP100 FIRMWEAR SET IS ALIVE AT BLINK PLZ TELL ME HOW CAN I SOLVE IT THANKS
COM3 [VCP0] selected
module v1.58
Device: LG-KP100
Checking data, wait...
Action: reset
Boot ...
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
sw version: .01 ULC2GL RELIANCE KP100 01 FL 91 V10d 404-83 SEP-30-2008 +0
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20090526-195117.B1E.bin
loading data...
data loaded
imei: 35588202436205700
reading eeprom-security_35588202436205700...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35588202436205700_20090526-195118.B1E.bin
reading eeprom-complete_35588202436205700...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35588202436205700_20090526-195124.B1E.bin
backup critical area Done
Check memory ...
Check memory Done
Write ...
reset...
done
Write Done
Finished, time used: 27 sec
Remove/Install battery now !
Phone must be SWITCHED ON !
Connecting, wait...
Connection Ok
Read info...
software version: KP100FL-01-V10d-404-83-SEP-30-2008+0
Done
Finished
Old 05-26-2009, 16:12   #2 (permalink)
nasirkhan007's Avatar
Member: 553445
Sonork: 100.1585581
Thanks Meter: 8,184
Infinity box not Supported At The Moment Use Free Flasher + Flash File And Flash Here Post Long Time Must Be First Use Search Button
http://forum.gsmhosting.com/vbb/show...=kp500+flasher
The Following User Says Thank You to nasirkhan007 For This Useful Post:
Old 05-26-2009, 16:14   #3 (permalink)
StRaNgE PeRsOn's Avatar
Member: 391445
Sonork: 100.1583575
Thanks Meter: 392
module v1.58
Device: LG-KP100
Action: reset
Boot ...
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
loading data...
data loaded
Check memory ...
Check memory Done
Write ...
reset...
done
Write Done
Connecting, wait...
Connection Ok
Read info...
Done
Finished
Repair EEROM and post result
Old 05-26-2009, 16:19   #4 (permalink)
ehsas_ghum's Avatar
Member: 171512
Thanks Meter: 1,034
Thumbs up Kp105
Originally Posted by nasirkhan007 View Post
infinity box not supported at the moment use free flasher + flash file and flash here post long time must be first use search button
my set is kp105 not kp500
Old 05-26-2009, 16:28   #5 (permalink)
Member: 391445
Sonork: 100.1583575
Thanks Meter: 392
bro repair eero thn tell me
I can help u
Old 05-26-2009, 16:31   #6 (permalink)
Member: 391445
Sonork: 100.1583575
Thanks Meter: 392
I solved some fones having infenion CPU by EEROM
not by flashing..
Even if u have an old backup of any Kp105 just restore it
The Following User Says Thank You to StRaNgE PeRsOn For This Useful Post:
Old 05-26-2009, 16:36   #7 (permalink)
Member: 426200
Thanks Meter: 13
Wink
module v1.58
Device: LG-KP100
Action: reset
Boot ...
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
loading data...
data loaded
Check memory ...
Check memory Done
Write ...
reset...
done
Write Done
Connecting, wait...
Connection Ok
Read info...
Done
Finished
your phone lgk105 but you selc lgk100
Old 05-26-2009, 19:00   #8 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Just make "sp-unlock" operation.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 05-26-2009, 19:06   #9 (permalink)
Member: 553445
Sonork: 100.1585581
Thanks Meter: 8,184
Bro Same Phone Not Deference I Try Many Phone
Old 03-18-2010, 07:39   #10 (permalink)
Hamidshah07's Avatar
Member: 504906
Sonork: 1604032
Thanks Meter: 141
dear infinity team i flash it many time repair eprom , repair orginal imei ..many time also do the sp unlock operation but the problem is same when i put the sim the lg kp105 is just blinking..plz help
Old 03-18-2010, 08:27   #11 (permalink)
haroon75's Avatar
Member: 450542
Sonork: 100.1590626
Thanks Meter: 61
try 2 sp unlock method #2
The Following User Says Thank You to haroon75 For This Useful Post:
Old 03-18-2010, 12:41   #12 (permalink)
Member: 392149
Thanks Meter: 199
bro download new files or change ur flash files and repair eerom i think
ur set is alive
Old 03-18-2010, 13:38   #13 (permalink)
Member: 294245
Sonork: 100.1602405
Thanks Meter: 115
just unlock with method 2
The Following 2 Users Say Thank You to ayaz ali For This Useful Post:
Old 05-11-2011, 11:04   #14 (permalink)
Member: 504906
Sonork: 1604032
Thanks Meter: 141
Thanks alot brother my problem is solve..thanks again...
here iws logs
COM8 [VCP0] selected
module v1.73
Device: LG-KP105
Action: "sp-unlock"
direct unlock method #2 (Airtel etc.)
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
sw version: .01 ULC2GL KP105 KP100 P16 00 ARB V10b ARB-XX DEC-27-2007
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP105_eeprom-static_20110511-150321.B1E.bin
loading data...
wrong database file: C:\Program Files\InfinityBox\Pana01\lge_gb3a_eep65535.cfg
error: can't load database v.0
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP105_eeprom-security_20110511-150322.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP105_eeprom-complete_20110511-150328.B1E.bin
Check memory ...
Check memory Done
Write ...
Erasing: eeprom-security
Writing: eeprom-security
probably you need to restore original imei after unlock process
Write Done
Finished, time used: 21 sec
The Following 2 Users Say Thank You to Hamidshah07 For This Useful Post:
Old 06-22-2011, 07:14   #15 (permalink)
jan123's Avatar
Member: 600482
Thanks Meter: 85
mee tested kp105 blinking just sp unlock #2airtel etc mode
COM4 [VCP0] selected
module v1.78
Device: LG-KP105
Action: "sp-unlock"
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
460800
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
sw version: .01 ULC2GL Greece Open KP105 00 30 V10a 202-XX APR-02-2008
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP105_eeprom-static_20110621-230914.B1E.bin
loading data...
data loaded
imei: 35996001059149500
reading eeprom-security_35996001059149500...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP105_eeprom-security_35996001059149500_20110621-230914.B1E.bin
reading eeprom-complete_35996001059149500...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP105_eeprom-complete_35996001059149500_20110621-230916.B1E.bin
Check memory ...
Check memory Done
Write ...
Write Done
Finished, time used: 20 sec
E2130 blinking problem.... aikonmani Z3X-Team Products 7 09-04-2012 16:37
Lg Kp105 Problem mic plz help omarfilali LG 0 03-29-2010 17:02
17/04/08 LG KE520/KE590/KM500/KP100/KP105/KP106 Full Support Added ! .:hack3r2k:. FuriousGold 110 06-15-2009 19:48
30/04/2008 LG KP100,KP105,KP105A,KP105B,KP106 Code Reader Added samigsm78 Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 9 05-05-2008 11:22
NEW: Full support for KP100,KP105 and KP106 Gobi VygisToolbox 23 04-11-2008 21:04
Page generated in 0.30786 seconds with 10 queries
