Old 09-19-2008, 18:06   #1 (permalink)
Member: 432679
Thanks Meter: 118
Cect q610 infenion cpu 7870
software version: 1.14
cable type: 1x12 (L12C)
platform: PMB: Infineon e-gold
searching adapter at COM8...
adapter found, version: 2000
pins: 12, plain
power cycles: 1
activation cycles: 10
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Press and HOLD phone Power button now !
detecting pins...
e-gold (A0)
result: Rx:6 Tx:7
time required: 25 sec
Power On !
saved: cect_Q610
==== log: [9/19/2008 10:20:53 PM] ====
COM8 [VCP0] selected
Device: LG-KG375
Checking data, wait...
Action: reset
Boot...
Press and HOLD Power button now (if boot does not start remove/install batery) !
error: wrong boot answer #1:
Release Power button now
Boot Failed
Finished, Remove/Install battery now !
Time used: 67 sec
KINDLY ASIST
Regards!
Old 09-19-2008, 21:33   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
what about reading flash?
Old 09-19-2008, 22:18   #3 (permalink)
Member: 432679
Thanks Meter: 118
COM8 [VCP1] selected
Device: LG-KG375
Action: read flash
Boot...
Boot Failed
Time used: 27 sec
Old 09-20-2008, 12:51   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Be sure that "Power" button in PinFinder is enabled and phone take power from PinFinder.
Press and hold phone Power button for some time.
Try to select another model (not KG375 but f.e. ZTE-225) and try to read flash again
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 09-21-2008, 18:33   #5 (permalink)
Member: 432679
Thanks Meter: 118
not happening
same problem
regards
Old 12-30-2009, 07:31   #6 (permalink)
Member: 295635
Thanks Meter: 18
COM1 selected
module v1.73
Device: LG-KG375
Action: reset settings ("format ffs")
Boot ...
e-gold: A0
loading...
error: can't run preloader: 5A
Boot Failed
Finished, time used: 5 sec
cect q610 n72 small copy smartengg Infinity-Box 13 01-20-2008 19:40
hi all i have cect q610 small n72 chnese unlock_solution Infinity-Box 1 11-14-2007 16:55
cect q610 pe calibration problame sachin_udai Infinity-Box 1 09-20-2007 20:26
Cect Q610 Pinout Need kabirhossain Infinity-Box 1 04-27-2007 17:41
Page generated in 0.16456 seconds with 10 queries
