01-09-2010, 14:56 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | LG KP110 Hangs at searching when i power on LG KP110 a bar starts to search ....after long time set goes on to menu ...but with sim card it hangs and restarts.............i tried to reset /format fss but facing error...........i have tried with code 2945#*# and did factory setting ...........but problem not fixed ........... COM6 [VCP0] selected module v1.39 Device: LG-KP110 Checking data, wait... advanced flash detection enabled Action: reset Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... error: boot failed: C4 Release Power button now ! error: unexpected answer during boot procedure Boot Fail Finished, time used: 12 sec Remove/Install battery now ! need help please |
01-16-2010, 12:26 | #4 (permalink) |
Freak Poster Join Date: Aug 2009
Member: 1105586 Status: Offline Thanks Meter: 112 | LG Kp110 hang and rest If use cable RJ45 (KG800) can see this problem(COM6 [VCP0] selected module v1.39 Device: LG-KP110 Checking data, wait... advanced flash detection enabled Action: reset Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... error: boot failed: C4 Release Power button now ! error: unexpected answer during boot procedure Boot Fail Finished, time used: 12 sec Remove) Try jumper TX Box to Rx phone Jumper RX Box to Tx phone Jumper GND Box to GND phone Here is Tx & Rx on Phone: Here is Tx & Rx Box jumper to Phone: This is results after jumper Tx Rx and use to Reset seting ,Format FFS: GOOD LUCKY. |
The Following 3 Users Say Thank You to huong2 For This Useful Post: |
05-25-2010, 14:05 | #6 (permalink) |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | No Need to Flash just make Reset n it is done successfully ,,tested by me,, LOGS: ------ COM5 [VCP0] selected module v1.39 Device: LG-KP110 Checking data, wait... advanced flash detection enabled Action: reset Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 352008020234719 file saved: C:\Program Files\InfinityBox\LGA\eeprom_352008020234719_LG-KP110_20100525-175819.B1E.bin .... reading _eeprom-ffs_352008020234719... file saved: C:\Program Files\InfinityBox\LGA\_eeprom-ffs_352008020234719_LG-KP110_20100525-175930.B1E.bin Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 122 sec Remove/Install battery now ! NOTE: CABLE USED KE500 |
The Following User Says Thank You to mobile_hotman For This Useful Post: |
LG KP110 Hang Problem Solved | zeerik | Infinity-Box | 1 | 05-26-2009 16:33 |
LG L600V hangs at "Refreshing" | zeerik | FuriousGold | 7 | 04-05-2009 00:12 |
lg u900 hang at 3 | surajrasaq | LG Hardware Repair | 1 | 11-16-2008 16:55 |
LG KC550 hang at start up? | Afzal Chiri | FuriousGold | 1 | 10-21-2008 13:19 |
lg u880c hangs at 3 on power up | gsmservices | LG | 6 | 07-26-2008 09:04 |
