09-29-2009, 06:38 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: india
Member: 500302 Status: Offline Thanks Meter: 157 | lg kp110 without sim card 112 calling restart kp 110 restart with sim card allrady full flash for this file KP110AT-00-V10b-ESA-XX-JUN-10-2008_full_code_alchemy[1].B1M.bin flassh log... COM1 [VCP0] selected module v1.39 Device: LG-KP110 Checking data, wait... advanced flash detection enabled Action: flash write Write: Firmware (code) Skip: File system Skip: Alchemy data Skip: Eeprom "smart write" active Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 352008023078543 file saved: C:\Program Files\InfinityBox\LGA\eeprom_352008023078543_LG-KP110_20090928-182702.B1E.bin .... Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write: Firmware (code) flash: 01227E22212200:FEEA0000000000 flash: 01227E22212200:F0B0FF00000000 write: 2nd chip area Write Done Finished, time used: 1925 sec Remove/Install battery now ! but same condition any body tested solution plz...... help for this problem imei righting--- see this log.................. COM1 [VCP0] selected module v1.39 Device: LG-KP110 Checking data, wait... advanced flash detection enabled Action: imei repair Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 352008021392508 file saved: C:\Program Files\InfinityBox\LGA\eeprom_352008021392508_LG-KP110_20090929-102834.B1E.bin .... Check flash Done Check space ... current eeprom imei: 352008021392508 Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 44 sec Remove/Install battery now ! plz.. all member plz..help Last edited by Wasim007; 09-29-2009 at 06:48. |
The Following User Says Thank You to Wasim007 For This Useful Post: |
09-29-2009, 06:56 | #2 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
The Following User Says Thank You to deepakgarg For This Useful Post: |
09-29-2009, 09:50 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | |
LG C2500 Without SIM Ok But Not On With SIM Card | Ankit Verma | LG Hardware Repair | 7 | 10-09-2010 08:48 |
2600 normally without sim card and restart wit sim | harish35200 | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 04-29-2006 13:57 |
S35 Card error without sim card.... | questman | Siemens Hardware Repair Area | 0 | 07-29-2002 19:39 |
mw3026 Sim lock without sim card | xDAN | Infineon C16X M51 & ARM7 M52 BASED | 2 | 04-17-2002 04:20 |
mc 916-sim locked without sim card | F C | Infineon C16X M51 & ARM7 M52 BASED | 0 | 12-12-2001 16:32 |
