12-03-2008, 09:01 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: NEAR YOU
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | >>> LG KP115 Fully Tested with Infinity <<< Here is the way >>>> 1. Select Model KP135. 2. Cable used KE500. 3. Read eeprom/full flash ok. 4. Did reset setting/ffs format for repair. Set fully repaired. Thanks to Infinity >>>>> Infinity Team plz add this model to list. I can send you eeprom/full flash backup readed out by Infinity software. Hope to see this model in our list soon >>>>> Here is format ffs test report >>>> COM5 [VCP0] selected module v1.36 Device: LG-KP135 Checking data, wait... advanced flash detection enabled Action: reset Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 352129020075991 file saved: C:\Program Files\InfinityBox\LGA\eeprom_352129020075991_LG-KP135_20081203-132340.B1E.bin ................................ reading _eeprom-ffs_352129020075991... file saved: C:\Program Files\InfinityBox\LGA\_eeprom-ffs_352129020075991_LG-KP135_20081203-132500.B1E.bin Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 117 sec Remove/Install battery now ! |
The Following 10 Users Say Thank You to zeel_zeel For This Useful Post: |
12-03-2008, 13:19 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @zeel_zeel Thanks a lot for information ! Please, read full flash from this phone and send flash backup files to [email protected] |
12-03-2008, 14:16 | #5 (permalink) | |
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | Quote:
Flash file readed out in two parts... Mail sent to Infinity team... | |
The Following 2 Users Say Thank You to zeel_zeel For This Useful Post: |
03-06-2010, 15:33 | #8 (permalink) | |
Insane Poster Join Date: Dec 2008 Location: Delhi (India)
Member: 919494 Status: Offline Thanks Meter: 6 | Quote:
Here is format ffs test report >>>> ==== log: [3/6/2010 7:39:31 PM] ==== COM2 [VCP0] selected module v1.39 Device: LG-KP115 Checking data, wait... advanced flash detection enabled Action: reset Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 352129020280799 file saved: D:\Program Files\InfinityBox\LGA\eeprom_352129020280799_LG-KP115_20100306-194001.B1E.bin .... reading _eeprom-ffs_352129020280799... file saved: D:\Program Files\InfinityBox\LGA\_eeprom-ffs_352129020280799_LG-KP115_20100306-194418.B1E.bin Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 302 sec Remove/Install battery now ! | |
The Following User Says Thank You to Mohd Amjad For This Useful Post: |
04-03-2011, 13:15 | #10 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update: Infinity-Box - News 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell. It's just an example for Alcatel, if you have another model you must select your model ! RJ45 connector pinout: Here is an information how to build your own cable: FAQ: Frequently Asked Questions, cables/pinouts |
>>> LG KP500 Direct Unlock with LG Rocker <<< | zeel_zeel | Rocker Dongle (By Legija) | 7 | 09-18-2009 14:03 |
>>> Permanently Blocked Alcatel E227x Unlocked Ok with infinity <<< | zeel_zeel | Infinity-Box | 7 | 09-07-2009 13:39 |
>>> K810i Red Blink Repaired with TP <<< | zeel_zeel | SETool2 | 2 | 10-14-2008 14:52 |
>>> LG Tool 2.8: What's NEW ? <<< | RNC_EBM | LG 3G (USB-Smart) | 19 | 05-30-2006 20:35 |
>>> LG G8000i - Flasher & Firmware NEEDED <<< | RNC_EBM | LG | 3 | 01-29-2006 09:46 |
