Old 06-18-2008, 10:04   #1 (permalink)
rea1One's Avatar
Member: 236564
Sonork: 100.1667122
Thanks Meter: 816
Red face LG KP130 unlocked (Tmobile)
COM47 [VCP5] selected
Device: LG KP130
Checking data, wait...
advanced flash detection active
Action: unlock
unlock method: standard
Boot...
Phone must be POWERED-OFF !
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: 01227E22212200:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
Boot Done
Set baud...
115200
Set baud Done
Check flash...
current eeprom imei: 35212602rea1One
file saved: C:\Program Files\InfinityBox\LGA\eeprom_35212602rea1One_LG KP130_20080618-170357.B1E.bin
version: -
Check flash Done
Check space...
finalization done
Check space Done
Check parameters...
Check parameters Done
Erase...
Erase Done
Write...
write: lock area-1
Write Done
Finished, time used: 51 sec
Remove/Install battery now !
The Following 2 Users Say Thank You to rea1One For This Useful Post:
Old 06-18-2008, 13:36   #2 (permalink)
Member: 563167
Thanks Meter: 39
but i cant unlock my shell is not sopport v21
Old 06-18-2008, 13:48   #3 (permalink)
mughalG's Avatar
Member: 315789
Thanks Meter: 3,428
what problem u face ? plz tell us to help u
Old 06-19-2008, 11:41   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
@rea1One
Thank you very much for test report !
Each test report with attached logs is very important for us so we can see how is Infinity-Box
software works and what is possible problems and successfully done work.
@cllins
Please, explain the problem more detailed
Old 06-19-2008, 11:46   #5 (permalink)
Member: 227343
Thanks Meter: 11
==== log opened: [18/06/2008 12:36:06] ====
Application: C:\Program Files\InfinityBox\LGA\LgA.exe
Loading data, wait...
[Infinity Box] v1.30
S/N: ***X:01XX
Wait...
Current device: LG KP130
Done
COM9 ready
Testing COM9 at 921600...
COM9 [VCP0] selected
Device: LG KP130
Action: unlock
Boot...
Connecting, wait...
Boot Done
Set baud...
921600
Set baud Done
Check flash...
current eeprom imei: 35212602116***X
file saved: C:\Program Files\InfinityBox\LGA\eeprom_35212602116***X_LG KP130_20080618-123703.B1E.bin
version: -
Check flash Done
Check space...
finalization done
Check space Done
Check parameters...
Erase...
Erase Done
Write...
write: lock area-1
Write Done
Finished, time used: 38 sec
Old 06-19-2008, 11:49   #6 (permalink)
maka_gsm's Avatar
Member: 309772
Thanks Meter: 31
Mate download the update install and unlock it.
Old 06-19-2008, 11:51   #7 (permalink)
Cheater -Don't Deal with him-
Member: 498158
Thanks Meter: 20
thanks enough we need unlock solution for all window mobile on infinity
Old 06-19-2008, 17:23   #8 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 213
Hello,
Please, explain your idea little bit more detailed.
Old 06-20-2008, 16:59   #9 (permalink)
Member: 498158
Thanks Meter: 20
which cable can i use for lg KP 130
Old 06-20-2008, 17:50   #10 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 213
Too lazy to run Infinity-Box Shell to see pinout ???
keyboard top
1.........18
1: Gnd
2: phone Rx (RJ45 pin-2)
3: phone Tx (RJ45 pin-3)
5: Gnd
15: Gnd
18: Gnd
The Following User Says Thank You to InfinityN For This Useful Post:
Old 06-30-2008, 16:19   #11 (permalink)
piyush.kothiya's Avatar
Member: 515506
Thanks Meter: 28
KP130 Unlock
Dear Friend
thank you verymcuh for your very good support.
RJ-45
RX 2
TX3
cable pi out 100000000000% works
Infinity Box version 1.30 for LG KP130
and i have done that, KP130 unlock via Infinity
thank you very much
piyush
Old 07-12-2008, 18:53   #12 (permalink)
joseck's Avatar
Member: 648607
Sonork: 100.1638674
Thanks Meter: 23
hi,which shell version did use coz mine is v1.21 and dont have
da kp130 model?pliz help
Old 07-13-2008, 14:35   #13 (permalink)
Member: 130995
Hello,
Just download and install all latest updates from support area and you will see new models and pinouts in Shell
Old 07-22-2008, 06:28   #14 (permalink)
Member: 565469
Sonork: 100.1613725
Thanks Meter: 8
Originally Posted by piyush.kothiya View Post
Dear Friend
RJ-45
RX 2
TX3
thank you very much
piyush
u mean no need ground?
Old 07-22-2008, 08:23   #15 (permalink)
Member: 202611
Thanks Meter: 51
COM7 [VCP2] selected
Device: LG-KP130
Action: unlock
Boot...
Connecting, wait...
Boot Done
Set baud...
115200
Set baud Done
Check flash...
current eeprom imei: 352126022960832
file saved: C:\Program Files\InfinityBox\LGA\eeprom_352126022960832_LG-KP130_20080722-095709.B1E.bin
version: -
Check flash Done
Check space...
finalization done
Check space Done
Check parameters...
Erase...
Erase Done
Write...
write: lock area-1
Write Done
Finished, time used: 159 sec
Lg Kp130 Unlocked Sucessfully With Et Box ashok_kumar459 ET-BoX 3 09-07-2008 09:40
LG KP130 Unlock with Vygis, Problem Error: Phone not respond powerplay83 VygisToolbox 2 08-22-2008 21:52
what about lg kp130 unlocking qaziomer Infinity-Box 5 05-25-2008 02:04
Lg KP130 unlock failed lobalt PolarBox 3 3 05-18-2008 14:23
what about lg kp130 unlocking BRANCO PolarBox 3 1 04-26-2008 16:25
Page generated in 0.28531 seconds with 10 queries
