LG-KP135 message and camera not open solved by format COM6 [VCP1] selected module v1.36 Device: LG-KP135 Checking data, wait... advanced flash detection enabled Action: reset Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 353955021363088 file saved: C:\Program Files\InfinityBox\LGA\eeprom_353955021363088_LG-KP135_20090212-154421.B1E.bin .... reading _eeprom-ffs_353955021363088... file saved: C:\Program Files\InfinityBox\LGA\_eeprom-ffs_353955021363088_LG-KP135_20090212-154837.B1E.bin Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 335 sec Remove/Install battery now ! http://i183.photobucket.com/albums/x...2122009419.jpg |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. |
