02-12-2009, 09:24 | #1 (permalink) |
Freak Poster Join Date: Dec 2006 Location: philippines
Member: 406299 Status: Offline Sonork: none Thanks Meter: 280 | LG-KP135 message and camera not open solved by format module v1.36 Device: LG-KP135 Checking data, wait... advanced flash detection enabled Action: reset Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 353955021363088 file saved: C:\Program Files\InfinityBox\LGA\eeprom_353955021363088_LG-KP135_20090212-154421.B1E.bin .... reading _eeprom-ffs_353955021363088... file saved: C:\Program Files\InfinityBox\LGA\_eeprom-ffs_353955021363088_LG-KP135_20090212-154837.B1E.bin Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 335 sec Remove/Install battery now ! |
The Following User Says Thank You to JMJ ALBERT For This Useful Post: |
02-12-2009, 20:39 | #2 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
after format dongle now even the maitance not open [SOLVED] | karouk | FuriousGold | 26 | 06-25-2009 22:26 |
NEC_Cect_P168 turn off with sim.. not Solved by Format | saiftc2 | SpiderMan | 2 | 03-14-2008 02:11 |
K750i CAMERA NOT OPENING | Nasmi | Cruiser Suite | 5 | 07-24-2007 14:15 |
camera not opened | jasmer | Universalbox | 5 | 06-25-2007 10:37 |
6020 camera not open | m.tahir | Nokia Hardware & Hardware Repair | 0 | 06-21-2006 19:13 |
