10-28-2008, 19:57 | #1 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 568259 Status: Offline Thanks Meter: 52 | LG KP135 successufly unlocked!!! this is the log for operation: COM9 [VCP0] selected Device: LG-KP130 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 353955020366322 file saved: C:\Program Files\InfinityBox\LGA\eeprom_353955020366322_LG-KP130_20081028-184318.B1E.bin .................... Check flash Done Check space... current eeprom imei: 353955020366322 ................................ finalization done Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done Finished, time used: 54 sec Remove/Install battery now ! |
The Following User Says Thank You to adilosse For This Useful Post: |
10-28-2008, 20:46 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
02 Nov 2008: LG-KP135, SFR-111, Bird-V5518+, ZTE-A136, Zong-A136 models supported | InfinitySupport | Infinity-Box | 36 | 06-21-2009 10:59 |
LG-KP135 message and camera not open solved by format | JMJ ALBERT | Infinity-Box | 1 | 02-12-2009 20:39 |
LG Kp135 TestPoint | Tracer Gsm | Infinity-Box | 2 | 01-30-2009 23:07 |
lg kp135 is suported sir? | sagemx1 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 0 | 01-05-2009 17:30 |
NEW - LG KP135 SUPPORTED - LG Workshop v1.90SC is uploaded at support sites | Gobi | VygisToolbox | 18 | 07-03-2008 15:14 |
