05-07-2011, 12:00 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 37
Member: 141164 Status: Offline Thanks Meter: 36 | Lg kp170 after unlock no network Ill Be Thank Full For Any Help Regard Getting Back Fone At Previous Stage. Thanks Br. COM7 [VCP0] selected module v1.39 Device: LG-KP170 (under test) Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 00005283 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 350305260000001 file saved: C:\Program Files\InfinityBox\LGA\eeprom_350305260000001_LG-KP170 (under test)_20110507-115452.B1E.bin .................................................. .............. Check flash Done Check space ... current eeprom imei: 350305260000001 .................................................. .............. finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 64 sec Remove/Install battery now ! There Is A Diffrence Between Imei Of Fone And Curent Epprom Imei. Fone IMEI Is 357042021348157 |
05-07-2011, 16:47 | #4 (permalink) |
Member: 141164 Status: Offline Thanks Meter: 36 | Ok Guys Thanks For Ur Reply. I Did What u Said But Still No Luck I Cheaked Imei With Option*"06" & The Fone Imei Is All Zeros LIke This 000000000000000. COM7 [VCP0] selected module v1.39 Device: LG-KP170 (under test) Checking data, wait... advanced flash detection enabled Action: flash write Skip: Firmware (code) Skip: File system Skip: Alchemy data Write: Eeprom "smart write" active Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 00005283 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 357042021348157 file saved: C:\Program Files\InfinityBox\LGA\eeprom_357042021348157_LG-KP170 (under test)_20110507-164325.B1E.bin .................................................. .............. Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write: Eeprom flash: 01227E223C2200:FEEA0000000000 Write Done Finished, time used: 40 sec Remove/Install battery now ! What Is Way To Write Back The Reall Imei Of The Fone Thnx Br. |
06-20-2014, 09:42 | #6 (permalink) |
Freak Poster Join Date: Dec 2007 Location: nowshera pakistan
Member: 651119 Status: Offline Sonork: 100.1603096 Thanks Meter: 48 | lg kp170 after unlock no network problem solved with write eeprom backup file from infinity....... |
The Following User Says Thank You to pine mobiles For This Useful Post: |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
