-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   Lg kp199 (http://forum.gsmhosting.com/vbb/f296/lg-kp199-614162/)
Aamir_Zia 10-20-2008 13:49
Lg kp199
Phone Lock Successfully Readed with Chinese Miracle Software
then 2945#*# & Format NVRAM ...
Phone is now Free of Memory
I have the readed the Full FLASH file
Where to Upload ? I Forgot the FTP Address
Here is both LOGS
COM3 [VCP0] selected
module v2.64
Action: read codes
unlock method: read codes
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:508A:95E4
Connecting, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: 7S7339SA00-001-R1A
Version: EP2_HW
detecting structure #2...
0 done
44 byte(s) read
imei: 35313302003472
connection Ok
detecting structure #1...
0 3 4 5 7 8 9warning: wrong packet cs
12 done
157 byte(s) read
Phone lock: On
Network lock: Off
Network subset lock: Off
Service provider lock: Off
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
Phone code: 5252
Finished, time used: 18 sec
Remove/Install battery now !
__________________________________________________ ______
module v2.64
Device: Autodetect 6205-6227 NOR
eeprom backup enabled, it may takes several minutes !
Action: read NOR flash
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed disabled
boot step size: 0002
Boot Done
Initialize...
flash: 98004900000002:2AEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
921600
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.A340D78E.[KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-001-R1A.BIN_639C6C52].rpl
New firmware detected (2.64) :
- make "Read full flash" operation
- send "system_log_..." file to support: [email protected]
- send flash backup file(s) to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: A340D78E
identification#1 protocol ver: 04
ver. sw1: KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-001-R1A.BIN
ver. sw2: 7S7339SA00-001-R1A, AD93639C
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading: flash[KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-001-R1A.BIN]...
file saved: C:\Documents and Settings\Aamir\Desktop\KP199\flash[KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-001-R1A.BIN]_20081020-174207.B0M.bin
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_A340D78E_KP199_PCB01_GPRS_MT6226_S01.7S7 339SA00-001-R1A.BIN_639C6C52_20081020-174333.B0X.bin
Finished, time used: 733 sec
InfinitySupport 10-20-2008 16:00
Hello,
Please, upload files at rapidshare.com and send link to [email protected]
What is this phone pinout ?
Thanks a lot !
Aamir_Zia 10-21-2008 13:37
Cable Used = KE500
I am e-mailing you the File ..
InfinitySupport 10-21-2008 17:09
Hello,
Thanks a lot !
Files received, we will check it and add full support for this model ASAP.
Page generated in 0.15135 seconds with 5 queries
