04-21-2009, 08:37 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: UK
Member: 294200 Status: Offline Sonork: 100.1586184 Thanks Meter: 658 | Lg kp199 dead by infinity box COM4 [VCP1] selected module v2.70 Device: LG-KP199 Checking data, wait... advanced flash detection enabled Action: write NOR flash write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 chip: 0031:4AAE:591C status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .............. warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: LG-KP199__ffs... file saved: C:\Program Files\InfinityBox\MModule\LG-KP199__ffs_20090422-002856.B0E.bin Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Area: Firmware flash: 98004900000002:FFFFFF00000000 Write: Firmware detect device identification#2... detection phase #1... . detect device identification#2 finished Write Done Finalization ... Finalization Done Finished, time used: 404 sec Remove/Install battery now ! Thanks in Advance Z.K |
The Following User Says Thank You to zubairok For This Useful Post: |
04-21-2009, 11:41 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @indikait Your message with stupid advice was deleted, here is Infinity-Box support forum. If you want to talk about anything other you must write your messages in correct thread. If you have no good advice it's better to be silent than write bad advices. @zubairok Charge batetry completely with external power supply Flash phone with any firmware from support area. Make "format ffs" Press and HOLD phone "Power" button for about 1 min to make phone powered-on after flash/format. |
04-22-2009, 05:53 | #4 (permalink) | |
Member: 294200 Status: Offline Sonork: 100.1586184 Thanks Meter: 658 | Quote:
Thanks Again for your quick help Z.K MOBILES PAK | |
07-02-2009, 18:10 | #5 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 477510 Status: Offline Thanks Meter: 40 | Hi All Form plz help me lg kp 199 after flash daed with this firwmare file :KP199-00-V10e-ARB-XX-APR-09-2009_KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-002-R1C_En_Ru_Fr_Urdu_Farsi_Ar.B0M Note:FLASHING INF?COM6 [VCP0] selected module v2.58 Device: LG-KP199 Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active "format ffs" active write: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 chip: 0031:3689:1109 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is damaged, recalculation required identification#1 detection finished device-id: 937BB7B8 identification#1 protocol ver: 04 ver. sw 1: KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-002-R1C.BIN ver. sw 2: 7S7339SA00-002-R1C, 65657A3B ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-002-R1C.BIN]... file saved: C:\Program Files\InfinityBox\MModule\eeprom[KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-002-R1C.BIN]_20090702-214420.B0E.bin Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Area: Firmware flash: 98004900000002:2AEA0000000000 Write: Firmware Area: Eeprom/ffs flash: 98004900000002:2AEA0000000000 Write: Eeprom/ffs detect device identification#2... detection phase #1... . detect device identification#2 finished Write Done Finalization ... formatting... flash: 98004900000002:2AEA0000000000 Finalization Done Finished, time used: 1607 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
07-02-2009, 18:15 | #6 (permalink) |
Member: 477510 Status: Offline Thanks Meter: 40 | Hi All Form plz help me lg kp 199 after flash daed with this firwmare file :KP199-00-V10e-ARB-XX-APR-09-2009_KP199_PCB01_GPRS_MT6226_S 01.7S7339SA00-002-R1C_En_Ru_Fr_Urdu_Farsi_Ar.B0M Note:FLASHING INF? COM6[VCP0] selected module v2.58 Device: LG-KP199 Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active "format ffs" active write: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 chip: 0031:3689:1109 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is damaged, recalculation required identification#1 detection finished device-id: 937BB7B8 identification#1 protocol ver: 04 ver. sw 1: KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-002-R1C.BIN ver. sw 2: 7S7339SA00-002-R1C, 65657A3B ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-002-R1C.BIN]... file saved: C:\Program Files\InfinityBox\MModule\eeprom[KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-002-R1C.BIN]_20090702-214420.B0E.bin Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Area: Firmware flash: 98004900000002:2AEA0000000000 Write: Firmware Area: Eeprom/ffs flash: 98004900000002:2AEA0000000000 Write: Eeprom/ffs detect device identification#2... detection phase #1... . detect device identification#2 finished Write Done Finalization ... formatting... flash: 98004900000002:2AEA0000000000 Finalization Done Finished, time used: 1607 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
07-02-2009, 23:48 | #8 (permalink) |
No Life Poster Join Date: Mar 2004 Location: world wide
Member: 57836 Status: Offline Thanks Meter: 47 | i never killed a phone with infinity software i did with other tools so if any phone dead by infinty, must be sone thing wrong happint, so chek again best reguards |
08-26-2009, 08:11 | #9 (permalink) |
Freak Poster Join Date: Oct 2006 Location: ...::(Pakistan)::... Age: 43
Member: 375590 Status: Offline Thanks Meter: 45 | My kp 199 dead after flash i just want to change language packge.i tried different ver but mobile set can't be on, i also format ffs and change imei,but nothing .plz infinity team help me. |
08-26-2009, 08:25 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @rizoo Post answers for all questions: What MModule version you have used ? Do you see any errors during flash process ? Did you checked battery voltage ? |
08-26-2009, 10:18 | #11 (permalink) |
Member: 375590 Status: Offline Thanks Meter: 45 | yes sir, i have v 2.82 and there is no error during flash , all process done successfully and i'm using Digital Voltage Supply (with 4.42 Volts) plz help me' and thanks so much for your Quick Reply. |
08-26-2009, 12:51 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, 1. download latest MModule 2.84 2. try to flash phone with different flash files from support area 3. make "format ffs" in "complete" mode after flashing |
08-28-2009, 19:27 | #13 (permalink) |
Member: 375590 Status: Offline Thanks Meter: 45 | Now i'm downloading MMmodule ver 2.84,and also write all firmware from downloading infinity support area.format ffs.but my kp199 can't power on.i'm not using cable.i'm using direct RX and TX from PCB.all process done successfuly.and my set was working ok before flashing.can u help me infinity Team? |
08-29-2009, 08:29 | #14 (permalink) | |
2. What is your phone battery voltage ? 3. Did you tried to press and HOLD phone "power" button for a long time to make it powered-on ? | |
is lg km380 supported by infinity box? | hyber_99 | Infinity-Box | 3 | 08-07-2009 01:07 |
lg 195 repair by infinity box | navnath randive | LG | 1 | 08-01-2009 18:55 |
kg290 got dead by infinity box. | Umair Rashid | Infinity-Box | 9 | 02-09-2009 08:14 |
Lg Kg245 Kiled by Infinity-Box Revived by | KhalIman | Infinity-Box | 24 | 01-09-2009 15:50 |
C2200 Dead By Infinity Box | alamgarh | Infinity-Box | 4 | 02-22-2008 10:02 |
